Technical  Clutch replacement
Maybebaby
Leeuwarden
I have a Panda from 2005, a semi automatic. The clutch is broken I've decided to repair it myself. My question is, what's the difference (if there is one) between the clutch of a semi automatic and manual. I can't find it anywhere, and I don't really want to take my car apart, only to find out that I've ordered the wrong part.
2005
Mileage
137000
After fitting it you will need software to set it up
Looking for a clutch catalogue now
Back shortly
Sorry non of the catalogues were that helpful
Is the only listing I could find that mention it
None of the catalogues show a different part for number of the dualogic
None of the catalogues say except for dialogic or excluding dualogic
In fact none even mention dialogic including eper
I'd message the vendor before ordering, to be double sure, but it would appear to be the same
My understanding was the gearbox and clutch is the same in both manual and DuaLogic.
Are you confident the symptoms point to clutch? Plenty of problems reported with DuaLogic robot around that age.
At that age I would seriously consider replacing the input shaft bearing and seal (and driveshaft seals) whilst the box is off.
At least check the input shaft for play
Alright, thank you for all your help! I will contact the vendor about the part.
I had it tested at a garage, It's quite worn down. Also it's slipping, and refuses to go in neutral.
That's a good plan, to also replace that while I'm in there.
