yeah sorry confusion is prob my fault for calling the inner boots CV boots, but yeah as Ziggy says you can leave the outer boot and hubnut and everything in situ, just take the two bolts that hold the hub to the bottom of the shock and then pull the top of the hub outward and the shaft will fall out the cup on the diff. And on the other side just remove the clip that holds the boot on and when you drop the box off the shaft will come out the cup on the other side...
