Technical cinq hates me,caliper prob
Status
Not open for further replies.
custard
Status: DEFCON Grumpy
Edinburgh
right then,yet another simple job on the turbo cinq turns into a problem
went and got the bits i needed for the gt upgrade. lovely blizzard today which cost me some time :(
after the snow died back i got cracked on.struggled with some tight/seized nuts but got the drivers side done.unfortunatly the calipers dont fit under my wheels!:cry:
i can get the wheels on and they brush the rims but as i torque the nuts done its solid on the caliper *sigh*
ive left that one on for now as im cold,wet and a bit peeved to say the least.
so can i shave the calipers down a bit?i dont have an angle grinder or power at the car so im hoping i can do it with the dremel?
hope so though it will be a pain running up and down 3 floors to test them
OP
OP
custard
custard
Edinburgh
14" minilight replicas with standard cinq sporting spacers
where the bloody hell is
harsh mate.... but to be honest its down to the design of your wheels!! (n)
shaving the calipers, and or bigger spacers to help the spokes clear the calipers are your only options.
apart from gettin different wheels of course :p
Hellcat
zombie nation
on the A684
I wouldn't be shaving any metal off the calipers - you might just upset the stiffness of the caliper.
OP
OP
custard
custard
Edinburgh
i'll need to have a look tomorrow.no cash for new wheels at the mo im afraid unless anyone wants to donate some ofr a fiver ;)
i dont know if i would want to go with spacers but it depends how far out i would need to go as the calipers are pretty much to the rim before i bolt it down.
would only be a few mm shaved of the caliper at its highest point.IIRC someone in the cinq brake thread did the same
GhostWKD
Winning
Banbury, Oxfordshire
my ml's even on std calipers needed 5mm and 3mm spacers (now have 10mm hubcentrics) as even with 5mm spacers it scrubbed on the caliper, due to the flat inside spoke design of the minilites :)
OP
OP
custard
custard
Edinburgh
well theres not a lot in it though as to whether spacers would keep the wheel out far enough i dont know. with the wheel on and the the nuts 'just' on the thread they are brushing the alloys rim.so when you think of the amount of thread it could be as much as 10mm+
whereas im leaning towards shaving the calipers down TBH
in this pic i assume they are shaved down(from the gt upgrade thread) as mines are a fair bit higher than that at the front edge
Liam
hi friends :waves:
Scotland
Nightmare! I'm unsure of shaving bits of the calipers, dunno if it would lead to a static or dynamic imbalance at speed.
Liam
OP
OP
custard
custard
Edinburgh
im hoping not as turbocinqy 1250 hasnt posted anything and is pushing a fair amount of ponys
Liam
hi friends :waves:
Scotland
I was writing that post before you posted those pics, TBH that looks like a machining job.
I'm the same as yourself, simple sounding jobs become crusades on these wee cars!
Liam
OP
OP
custard
custard
Edinburgh
well i just had a little 'test' :eek: looks like the dremel with a sanding drum will take it down fine.must be a fairly soft alloy
Hellcat
zombie nation
on the A684
Which are you cutting down? The wheel or the calipers?
OP
OP
custard
custard
Edinburgh
caliper,wont be touching the wheels. basically if you look at the red ones they have an angles area facing out in the pics.that shouldnt be angled.
im looking at flattening it off without that angle.
its one of these things,i'll just have to take a bit off and try it,if i had been a bit smarter i would have taken the fitted one back off as i'll have to fit the one im working on to the other side :eek:
Kent
Mine looked like that in the picture and had no sanding/grinding down :confused:
On the pic posted, the smaller one is the old cinqi one, the bigger one is the GT caliper.
OP
OP
custard
custard
Edinburgh
must be a different caliper type,bugger! well on theones i have that angles area is sqaured off and actually gets higher as it comes towards that edge.
so im looking at takeing a few mm off.
just wondering how much clearence should i have from the wheel.eg is 1mm enough clearence?
OP
OP
custard
custard
Edinburgh
yeah that was my thinking,i'll shave a bit tonight and then look at it tomorrow.
one of those things,cant really see how much needs to come of till i try it up after taking some off.
as they say in andromeda 'its never easy'
Kent
yea seems to be :confused: Mine look exactly like the ones in aarons first post :) Though mine came of a bravo ;)
Status
