right im back.took a break from the car as ive been royally pissed off and was even considering selling her for spares or repair as ive tons to do and MOT and tax looming!
right went out today and 1st inspected around the car for leaks with none evident. resevour was still filled with fluid.
did see a patch of what looked like fliud on the bulkhead but assumed it was from the last bleeding.
proceeded with the bleeding but as per peaster2k's suggestion started with the rear drivers
ok and no air
passenger front which i re changed the brake pipe with a fiat one
ok and no air
rear passenger
air tastic,pumped through a full resevour and it still pushed air.
noise was there with every pipe
removed the servo pipe and the noise went?? re tried bleeding but still filled with air.
swore a lot!
looked around the servo and master cylinder,cleaned all around it with brake cleaner and gave it a few pumps...............
well somehow a pipe has burst/split/leaked around the retaining clip on the bulkhead to the side of the servo,im assuming its the pipe to the rear passenger. really weird as this has been in no way touched whatsoever.can only assume its been weak and just 'went'
may go posh and order them from fiat to save me ripping them out and getting them made up.
looking at
EPER it looks like the 2 rear pipes come from a union at the front so it would only be a short pipe?anyone confirm that?
