General Help Cinq with 1.2 8v mpi transplant
Liamt
I installed a 176a8000 engine to my cinq
Unfortunately car doesn't run well with map sensor connected
Runs much better without
Does anyone have a diagram of vacuum lines for 75 engine
Everything is from 75 car.. manifold throttle body etc..
I have the 4 injectors wired up to the spi loom batch firing
The car doesn't like starting without a bit of throttle.
But when running without map sensor revs quite well although obviously burning rich and burbling a bit.
With map sensor connected its misfiring and stalling.. tried another map sensor same issue.
I don't have any vacuum leaks. Sprayed brake cleaner all round manifold connections injectors etc.. no change
What kind of top speed are people getting with 75 engine and sporting gearbox.
Is there any gearbox thats straight swap that say can give 60 mph in second and a higher top speed.?. Without killing acceleration totally
Model
Cinquecento sporting
Year
1995
Mileage
50000
