Technical  Broken springs
Fasolt222
Falkirk
Well that’s both my front springs on my 2016 Trekking broken together. No harsh driving, and only had it since August. :mad:
Did Fiat acknowledge this as a fault, or not?
Are the Trekking springs different to non trekking models?
Broken springs seem to be a issue generally these days. It affects lots of makes and models. I think it is a combiation of lighter springs (less weight = improved fuel consumption) and more potholes and speed bumps in the raods. Not an acknoledged design or manufacturing defect as far as I know.
Check shop4parts for fitment detail..
One other thing to consider -- if the upper bearing has seized then the spring will be under torsional loads it wasnt designed for..
They are easy to check when it is all apart :)
https://www.fiatforum.com/grande-pu...ice-replacement-front-spring-replacement.html
Can be done yourself if you don't mind a bit of dirt and swearing at sticky bolts. I did mine but didn't have spring compressors (cheap pair can be bought for less than £15), so I took it to local mechanic who put the spring onto the strut (for free only took him 3 mins). Then brought it home and mounted to the car.
£200 for a pair is taking the pee, unless Fiat have started using performance progressive lowering springs as OEM replacements :)
I was looking to do it myself.
Fiat dealer quoted £200 parts and £180 to fit !
These are £44 each!
https://www.autopartspro.co.uk/sachs-8104403
Anyone any experience or knowledge of them? They are the longer trekking ones.
Sachs are a very long established brand..
I have no knowledge of this product..
My 1981 Sachs suspension didnt use springs
Which 'parts' did FIAT quote for
Bearings.. mounts bolts and new nylocks ?
Or just the springs?
