Technical  Technical Question - Springs
Metropolis
I'm thinking of buying a Qubo trekking but read it is has a 20mm higher ride height than the standard model and suffers body roll.
I've searched and there are no after market lowering springs available, my question is can you fit a set from the standard Qubo onto the trekking Qubo?
Thanks.
Hi and welcome. Buy it and enjoy it as nature (or at least the guys in Turkey) meant it to be. They don't roll that much unless you are a poorly qualified motoring journalist saying what the petrolheads expect him to say. The tracking looks good and will handle real roads very well at a brisk pace.
Take one out on a extended test drive, happen you will find the roll is not a problem, unless your expecting sports car performance, in which case the Qubo is not the car for you.......
Cheers Qube O.
my trekking qubo is no higher than a qubo mulitjet
in fact it has a engine guard under the sump that will bottom out on some roads and speed humps I wish it was higher like the 4x4 kango
