A bit more than a week ago I posted somewhere on here about Becky's spectacular strut blow out. I'll try to load some pics now.
Thanks Ben that seems to be working good now.
So about a week ago I had an in depth look at it all and came to the conclusion I might as well do both sides properly - struts, springs, bump stop/gator and top mounts - as I can see issues with them all. I've also got a N/S (LH) gearbox driveshaft seal to do so might as well get that out of the way too.
I've been busy with other stuff - Motor cycle/lawnmower repairs etc - so Becky has been "limping" the 2 miles to the shops and back with Mrs Jock this week past whilst I decided exactly what I was going to buy. The only real variable was whether the strut pinch bolts were going to be reusable so I gave them a very vigorous brushing with my wire brush and soaked them in Plus Gas (twice) a good 24 hours before giving them a try. It took my power bar to get any movement at all, seemed to be moving but tight and didn't have a "nice" feel to it. More Plus Gas and worked it back and forward a few times when, Oh dear, it all went slack and the bolt sheared!
You can see from the next pic that the thread really looked quite good (after being attacked with the wire brush) but obviously just really corroded into the threads.
I could probably get them to undo with heat but I prefer to just get 4 new bolts and nuts for safety. I'm going to try my big CP "rattle" gun on the next one just to see if it will move it.
Regarding the driveshaft seal in the gearbox. When I've got the old strut off (he said with confidence?) that will leave the hub sitting in the bottom ball joint. Anyone know if it can be moved far enough outwards without undoing the bottom ball joint to allow the inner driveshaft joint to be withdrawn from the diff so I can replace that seal? or am I better to just split the hub away from the bottom arm altogether?
