Technical  anyone got any ideas??
hotrock
i have a 2001 1.9jtd multipla with a heater problem :bang:
its the model without aircon. Normally i wouldnt post but i have tried everything that everyone has recommended, but nothing worked (n)
the blower motor wasnt working so i thought "fuse/relay" (n)
checked the power going to the motor, none (n)
bypassed a multiplug thats common to overheating, still nothing (n)
even forked out a fortune for a new resistor and blower motor (n):bang:
Anyone got any ideas??? anything welcome lol
Hi, I lost power to the heater blower,so i cut into the two wires that go to the blower, and attached a 12volt power supply, this has worked for me for the last 2 years, the + cable had broken some were in the wiring loom,just got round the problem with a new supply to the blower. hope this helps.
Under the centre console there is a connector, which is prone to work its way loose - not the connector, the wires attached to it, there is a thread somewhere explaining this.
When i had this problem all i did was stick my head under, move the wires and the blower kicked in. Havent had a problem since, did your car have the On screen thermometer? As this normally disappears at the same time.
https://www.fiatforum.com/multipla/...r-fan-not-working-please-help-if-you-can.html
scroll down to under peats post.
Good Luck
