Technical AEB warning light always on + flashing odometer
Tipo061
United Kingdom
Has anyone else had this occur before. Aeb light always on and continuous flashing odometer.
It's a 2017 but is still under 1 year warranty from Spoticar (which I believe is owned by FIAT/Stellantis)
TBH.. Looking less likely
But.. You have options
1st would be to get it plugged in and discover what isn't communicating,
A dealer may well charge £130 for this..
A private reading with AlfaOBD or MultiECUscan should have the same effect.. For significantly less 🙂
Look on the forums MES register for options
Or tell us where you are based
I am near the M4 😉
I am near the M4 😉
These are the codes I'm getting from my basic OBD reader
Surprised they give 1 year at that age 3 month maybe
Best contact them asap about it
Hopefully it will be covered but when they see the price of a radar sensor probably not
I've got in touch this afternoon they said it will be £125 for the diagnostics which will be refunded if it is found to be under warranty. Not sure of the cost if it isn't under warranty as I can't find any prices for new part only used
Told you... 😉
Anybody near you on the MES register?
Might save you some grief.
A day's lost at a dealer and £100
Looks like there's someone reasonably close to me in the NE, might drop him a message. If there is work that needs doing would a garage accept these diagnostics or demand to run their own?
Again.. Down to the garage
When I spent £600 a year in servicing.. They were very helpful with warranty
IF you get a good indication of where the communication issue lies.. Might even clear for a short period..
Then you have confidence your £125 will be wisely spent
TBH you have done well to get those 3 codes... Google them
It will give you a flavour of what is being flagged by the vehicle.
