Technical  Battery Warning Light
Dac1952
Sussex
Battery warning light illuminated. Checked all fuses, connections, feeds and earths, all ok. Fault codes logged in steering ecu for low voltage. But the power steering is working fine. Alternator is operating correctly too, even under load. But other than the warning light, the car is running completely fine.
Changed battery for new battery to be sure.
Cleared error but reappears after car has been running for a few minutes.
All fuses are fine and receiving a healthy voltage and are clean.
Had water pump replaced yesterday and this has occurred today.
Model
Tipo 1.4 95 Easy no stop start
Year
2018
Mileage
35000
Sounds like a cable was dislodged while doing water Pump?
Thinking it’s the cable between alternator and ecu as that’s a signal cable in addition to the cable to the battery
No luck as yet but am getting a rather dodgy error code which is P062500. Also been accompanied by Check Brake Control light flashing at random.
Who loves a fiat!
