R rinos Patron member Joined May 18, 2020 Messages 4 Points 1 May 16, 2021 #1 I have removed the roof shell and now wondering how does the cross brace come off? Is it weld in or can it be tapped out? Photo exclosed.
OP OP R rinos Patron member Joined May 18, 2020 Messages 4 Points 1 May 16, 2021 #2 I think it is welded. Can you buy a replacement?
B Bigvtwin996 Established member Joined Jul 19, 2011 Messages 1,350 Points 432 May 16, 2021 #3 welded in... you should see a few spot welds... either drill them or get a spot weld removal bit..... they are no replacements available..... you need to either cut out the front mounts and reposition them at the rear for the roof frame or make some up...
