Baglady1990 are they collecting it as very slow and scenic route for you if they're not....
100% slow!!! I’d never make it otherwise I’ll be crawling there!
Ok y’all engine changed at 500 italia in bury ... new rad new condenser picked it up yesterday ... when I got home I noticed coolant at min and a bit below when it cooled down so I topped up and bled as heard the water sound behind dash ... just been on motorway to my friends place and back & coolant back down to min again ... ? I’ve topped up twice since yesterday (between min & max both times) yet it keeps going back down to min ?? I’m at a loss I’ll ring the chap again tomorrow for advice but I have to say I’m at the point now where I’m ready to give up altogether no car is worth this stress!
I’d rather get the bloody bus!
Did the 500 Italia guy not check the whole stuff including test drive?
What part of the cooling system did they NOT change ? that should be the only place left where the problem is...
Bonnet can have different reasons - did they take it off completely for better acces and then not adjust well after re-assembly?
My boot needed slamming because of a valve cap hidden in the recess around the lock bracket that blocked the lock. Was hard to see hence took a while to find..[/
He changed everything as far as I’m aware ... test drove it and seemed to be very thorough but obviously the test drive was not over 70mph and not a long enough drive to show up an issue!
My thoughts are leaning to the heater matrix .... [emoji37]
Must have had bonnet off for access though I’ve no idea about re alignment or how
Ugh I’m just ready to give up .. scrap the car and use public transport all this is doing nothing for my mental health if I’m honest!
I think this is going to be something frighteningly simple
Like a cracked pipe or a clip that needs pinching up.
And Breeeeeath!
Have a look under the car, when it stops raining.. and look for any wet areas, leaks or drips. Coolant is pink and goes crystallised when it dries, so you can quite easily spot any leaks.
My guess is the system is just purging itself.. the amount it's "losing" would be pretty obvious under the car. So.... if you can't see any leaks, just keep an eye on the coolant level and top it up to just under MAX as needed.
I think it will suddenly stabilise when the car has moved all the air out (gurgly dash suggests there is still some air in there.. it'll come out when you use the car with some revs and the heater on MAX (red spots MAX, not fan speed MAX) - the hot coolant to the heater has to run uphill so it doesn't flow very strongly when you just idle the engine.
The bonnet shut is either they removed the bonnet (not too likely if they dropped the engine out from below...) or the valance (aka "slam") panel (since it;s the easiest way to get the exhaust manifold out. The latter has the bonnet latch in it, which is connected to the car via the release cable, so to remove the valance panel from the car, they would have disconnected the latch from the panel first.
It sounds like it just needs a bit of adjustment. The latch needs to be higher /closer to the "loop" on the bonnet. It's probably got slots rather than holes, so loosen the two (?) M6 nuts on the latch and see if you can physically raise it a couple of millimeters relative to the valance panel. Tighten it up and Roberto is your mother's brother.
Ralf S.
Do what I described earlier with the bleed screw. It must be just air. I’ve done so many of these from empty, the6 change a bigger to purge completely. As mentioned, a bit of throttle will help to push the coolant round and the gurgling will go.
The bonnet has clearly not been put back properly. I don’t see why they would have removed the bonnet catch. Does it line up properly with wings and bumper?
The heater stopped gurgling before, so it can stop gurgling again. If it was a leaky matrix, you would have a wet and pink carpet by now.
If it's producing heat when you turn the temperature up, then the matrix is okay.
so I think it's just air.. the pipes to the heater are higher than the pipe out of the block (I'm more familiar with the 1108cc.. but it's the same family of engine) so hot coolant doesn't naturally flow into the heater... it needs help from the pump (i.e. some revs) and for the pipe where any air collects to be bled (though I've not seen a bleed screw on the missus' 1.2 yet).
I would check the level and then take it for a usual kind of motorway run that showed up your original problem.. that'll help it purge so the level should finally settle down.
Ralf S.
Yes, they haven’t fitted it back properly. They are a pig to do. I hate replacing them.
It’s obviously not got bent hinges as no accident so looks like it needs some adjustment on the four hinge bolts on the underside of the bonnet.
How’s the fit at the front? I think it looks like it needs to move forward a bit.
