So be it!! I’ll just be glad when this journey ends (pun intended)
Swap the radiator cap with your other 500
Go drive
Thats 2 minutes of your time vs £800
Worth a shot !
Go drive
Worth a shot !
Go drive
Worth a shot !
Went for a drive on motorway.... popped coolant again!! New engine it is then no more to be said!
Even with a blown head gasket you would not expect the coolant to pop its top, this is not normal behaviour. Usually coolant would get sucked into the engine, expelled though the exhaust or mixed with oil, it’s rare it would highly pressurise the coolant without there being other symptoms like your own personal cloud of steam following you.
If you have any enthusiasm left, it may be worth a punt to remove the radiatore, check the condition, flush it to buggeration and/or if it looks ropey actually even replace it
I'm now wondering what state the heater matrix will be in. Running the car on plain water could have weakened or even perforated it. Also if any residual sludge gets back into the new radiator and replacement engine, it won't be good. Easy enough to flush through the pipework, but will that be enough? Replacing the matrix is a nightmare job, since the heater box is just about the first thing to go into the shell when the car is built.
If it’s Club500Italia you are in safe hands. They really know their stuff.
On a related lighter note I had a call from a lady this morning who I’ve helped out with her broken door handle before saying she “boiled over” yesterday. Car told her to stop but she drove about 3 more miles to get home [emoji51][emoji51][emoji51].
I went through it on the phone what it could be and said “have you checked your oil?” She has had the car a year and never checked it. I told her to do so. It didn’t register on the dipstick so she put a litre in. I told her to put more in and recheck the dipstick and that was most likely why she had boiled over. In the year she has had the car she’s never raised the bonnet. [emoji30]
Hi Everyone
Sorry im coming to this late on.
I have noticed over the years that many 1.2 puntos/panda cars blow head gaskets twice, the first time it gets repaired because the head gasket has gone, the second time it gets repaired the second repairer looks at why its blown again.
often stone chips get into the lower section of the bumper and brakes away the small aluminium fins off the bottom 2 or 3 inches of the radiator, this causes the radiator to become less effective and so the car begins to over heat slightly causing head gasket blow no1. repair is done and your on your way with fresh coolant, later on symptoms begin to reappear and a build up to head gasket no 2, this time the mechanic notices the radiator is missing fins off the bottom half. head gasket repair is done with new radiator and all is good.
This is great if you can do all the work your self because its the labour that is expensive.
I suspect from reading through quickly. the bottom of your radiator is loosing its fins giving the engine less effective cooling making it run a little hotter maybe making it loose a bit of water, your water pump has probably never been changed before your ownership and now you have done it with a cam belt you have protected yourself, in your position i would check the radiator bottom by looking through the grills in the lower half of your bumper and if you see the fins are missing then look into having the radiator changed this will give you much better cooling and will reduce the chance of head gasket failure, read earlier about letting the system self bleed with the cap off for about 20 mins before putting the cap on to then bleed the heater hose and then top up to the levels rqd.
I hope this helps
Tim
