- Joined
- Sep 14, 2009
- Messages
- 19,849
- Points
- 3,391
At the risk of being overly simplistic, a loosely fitting &/or corroded fuel pump connector? Removing and replacing it might just have been enough to get the current flowing again.
I've lost track of the number of computers I've 'fixed' by powering down, taking the cards out of their slots & replacing them.
I agree and TBH I'm pretty anal about protecting stuff from corrosion. The fuel pump wiring was dusty but surprisingly dry and no signs of metal worm. Saying that, some sound deadening mat around the pump top and under the seat would be a good move. The plastic pump access cover barely keeps the weather out.
To test the fuel pump I used some small spade terminals (just right for the larger contacts) and two core wire to connect to the battery +ve and earth via a chocolate block connector. The actual plug is open enough at the back to get a multimeter prod onto the terminals. It's very handy for checking power at ignition on.
I've pulled off the steering column bottom cover. The ignition switch all looks fine and neat really not what I hoped for. Rain has stopped any more play.
