Technical 1.2 Injector Seals
Yes they are about £1.80 each, standard Bosch injectors
Should be pretty obvious if they are leaking and worse under heavy loads
But it's far more likely to be a fault with the breather tube
Either perished, split, loose or unplugged, very common cause of petrol smell in the cabin
Cheers mate,
What breather pipe would that be? Any of the pipes connected to the air filter box? Or different pipe? :)
This, breather tube
And sometimes this is damaged or missing on the throttle body
If you need a new breather check here first, some listings say they are for the panda but aren't the correct part
So I had a check, none of the hoses are split, nor the airbox-throttle body bung is damaged.
I'm not entirely sure it's the injector seals either as there doesn't appear to be any petrol leaking (when revving) from them.
It's not a exhaust gas smell, it's definitely petrol fumes.
I have checked fuel filler cap and no damage to the seal and still clicks on correctly.
Maybe need to take it to a mechanic to find out.
Thank you for your help
Adam
Does it smell of petrol out of the exhaust
Are you sure its not from the evap
Drivers side rear wheel
Is it worse on startup
Reversing
At idle stationary
Slow or fast speeds
Reversing
At idle stationary
Slow or fast speeds
Hi koalar
The smell enters the cabin when I'm slowing down, when I turn the cabin fan off or switch the air inlet to recirc, the smell goes away so I feel it's definitely coming from engine bay.
When I open engine bay, it's very hard to tell where smell is originating from, as I originally thought it was the injector seals 🦭
Though digging through Internet and this forum, I think I may be onto something...
Last week I was going on a long run, so I brimmed my fuel tank. *click* squeeze squeeze *click* squeeze *click*. I think you mentioned the EVAP system, I'm starting to think I've damaged something? Perhaps the purge valve with the blue hose underneath throttle body?
No codes are showing, no EML light. So don't know if anything to do with charcoal canister?
Any thoughts would be appreciated
Adam
Never do this; there is a clear and specific warning in the handbook to this effect.
You may have got some liquid fuel into a part of the fuel system that's only designed to cope with vapour. It may disperse given sufficient time, petrol smells can linger.
The evap canister can be replaced if it's been flooded with fuel, but they're neither cheap nor readily available.
Hopefully a combination of time and not overfilling the tank in future will sort this out for you.
I'd be surprised if this were an injector seal fault.
Failed breather hoses used to be a common issue, but I think they are made from more suitable materials now.
Smell on small throttle opening sounds is more likely to be the little pipe going below the throttle body to me
Usually you can see damp oil where it's leaking
Often the clips are missing and the pipes loose
Spring missing from the air box is also common
