GitHub - pandamime100hp/fiat-panda-tjet-conversion: The Fiat Panda 100hp was released with an NA engine. The TJet engine is essentially the same NA engine though with a turbo mounted on it. This project is to document the process.
The Fiat Panda 100hp was released with an NA engine. The TJet engine is essentially the same NA engine though with a turbo mounted on it. This project is to document the process. - pandamime100hp/f...github.com
The question is if the pandapter works with the 1.2 69 hp bcm, I don’t know I those are the same between the 1.4 and 1.2Pandapter with a Bravo TJet ECU and Bravo TJet engine loom is definitely easiest and neatest way, although you can "roll your own" with a bit of care, soldering iron, wiring diagrams and bits of a Bravo main wiring loom too.
Don't know anyone who has used a non-Bravo ECU yet, but someone probably has.
Very tight for space, aircon makes it worse, underbonnet heat is a problem, and most off-the-shelf intercoolers are restrictive if going for over 150hp.
Lots of knowledge about if you search for it, mostly for 100HP upgrades, but some for 1.2 upgrades too.
YesThis is for the 1.4 100hp model unfortunately![]()
The pandapter was made to connect the ecu with the bcu am I wrong?You could contact Pandamime directly and ask him. I've only been involved in a couple of 100hp swaps so far, but have come across at least one based on a 1.2, although I didn't get to talk to the guy who built it.
I'd be surprised if the 1.2 BCU won't talk to a Bravo ECU via the 1.2 main loom, but I can't give a definitive answer yet.
(I do have a "spare" 1.2 and a Bravo TJet engine laying around at the moment though... so I could be interested in the answer!)
Thanks a lot!The Pandapter converts the main loom connector to use an ECU connector compatible with the Bravo TJet ECU. As far as I can remember, the Pandapter is only intended for use with the Bravo ECU, which is Euro5.
The 100hp main loom connector is correct for the Pandapter. If your 1.2 main loom connector is the same as the 100hp one, then theoretically it should work. If not, then perhaps Pandapter is not the way to go.
The engine loom has to use a Euro5 connector as used on the Bravo. So, if using an engine and loom from a Euro6 Abarth 595, for example, either the engine loom needs to be swapped for a Euro5 one, or the Euro6 loom ECU connector plug has to be re-pinned for the 94-pin Euro5 connector.
They are on here somewhere, see if I can find there user nameYou could contact Pandamime directly and ask him
No idea you can probably work it outI'd be surprised if the 1.2 BCU won't talk to a Bravo ECU via the 1.2 main loom, but I can't give a definitive answer yet.
