RDM1
Established member
And these 2 cables where? BCM? Or ECU?
Wait a moment I want to look at F18 in your fuse boxWhite and red you mean in the upper ECU loom?
It powers the ECU I thought it would be easier from here than at ECU end
Be a good start anyway to take a measurement from here to the ECU case
But it doesn't check the cable
As long as I'm cranking it's down there then when i stop it bounces back up to the battery's voltageIs that the lowest it drops
Or is that where it bounces back to after a few seconds
Doesn't sound rightI'm getting 6.91v on the ECU side is that normal? Ignition on and measuring from the back of the loom while plugged between negative and the red and white wire
