Technical '06 Panda crank sensor issue.....
Leave the lead on the red and white at the ECU
And put the other end on the black and purple, there is a bunch of them together
Test at ignition on, and cranking . This is the permanent supply to the ECU
The black and purple to the heatsink should be below 0.1 while cranking
Or if you can tell me where does the black and purple go to so i can use the multimeter with continuity to find it makes it so much easier this way
They connect to a black cable that goes to the battery
It's likely to be on the other ECU connector
Means there's no way to find it with continuity gonna have to visually find it and hope there's no similar color
The plug you mentioned a while ago that is located next to engine when you told me and it turned out to be above the fuse box?
You mean this plug with the gray lock on it? In the top middle of the picture?
I can't tell in the photo
Yelllow is mainly the starter and alternator
Blue is mainly the communication lines from the ECU to the body computer
The drawing aren't accurate
I'd undo both connector in the photo and visually check for corrosion
It rains more in Lebanon than it does here in the UK always look dry on the news
I think this is the yellow one because the blue one is nowhere to be found in this area unless it's fixed on the fender somewhere and this is the plug with the gray lock on it
These are the purple and black you're talking about?
And yes we get a lot of rain and snow and specially in my village as it ranges from 900m to 2800m altitude so we used to get a lot of snow but it's been a couple of years since we saw a decent thickness where i live (1300m) but the rain is unlike any year i have ever seen
Hahaha ok but you can zoom in I'm managing to steady my hand and get clear shots
Everything looks okay
That's the top one only
Starter and alternator control wires
There should be another slightly below
Unfortunately the drawing isn't very clear
0v normal with ignition on? On all 4 purple and black wires
