Technical '06 Panda crank sensor issue.....
ECU
These two line
The ECU heat sink and the white and red
Fuse and it's location is right below the 25 amps based on the cover mapping
It powers the ECU I thought it would be easier from here than at ECU end
Be a good start anyway to take a measurement from here to the ECU case
But it doesn't check the cable
And btw if you want a view of the fuse box wiring from beneath it's quite simple the compartment can be removed independently and flipped over
You mean voltage drop between the fuse and the heat shield?
9.7v between fuse and heat shield on the red and white wire side from the bottom of the fuse box
Going to prob the wire found it in the upper loom after removing the loom's back cover
Wait
Do the same test as earlier
Clear the codes
But this time log the battery voltage as well as the RPM
Let's see how far it falls and when the RPMs start against time
I'm getting 6.91v on the ECU side is that normal? Ignition on and measuring from the back of the loom while plugged between negative and the red and white wire
Rechecked it gave 8.54v on ignition on and 12v when closed between the positive of the battery and the red and white on the back of the ECU loom
Right
If we are measuring in the right place
We have a problem here
The ECU is permanently power
We are measuring the permanent feed
The ECU is told to wake up when the ignition is switched on
The draw increase, fuel pump kicks in, dash lights up, selector pump and so on
I would not expect a 3.5V drop and after a few second after the pumps have stopped it should measure the same as the battery voltage
