Technical  '06 Panda crank sensor issue.....
Well done in sticking with it
I think the voltage drop is higher than expected when tested at the engine block
At the time of testing it was not enough to stop the car from running,
It's an intermitantant fault, there's no guarantees that it wasn't tested just as it was working,
It need looking at and fixing properperly at sometime
However all the amps from the starter motor are carried through the bolt on the gearbox and if this was the main fault I would expect the engine to cut out and the starter not to crank, unless there is another bodge somewhere with another earth has been added
There is a bolt with an earth cable just below the windscreen, what is the voltage measure between the stud and the battery negative, with the main beam on and rear windscreen on
Reply to this question in the bottom and there is 2 the 2nd is not quite visible btw in the video it's a bit deep
  • VID_20240309_142422.mp4
    50.6 MB
But now i am wondering what this U1700 DTC refers to because that's the first time it ever showed up now if you can please tell me if the BCM does have a ground wire somewhere to double check it
Its all part of the same power ground problem
Managed to throw an eye from the downside up viewing everything from behind the engine, everything is normally connected without any apparent issue i even wiggled the cables to make sure nothing is loose or maybe broken and it all seem fine I'm gonna go try with the multimeter checking continuity to make sure everything is fine with the connection on both starter and alternator
No no no
Power and grounds can not reliably be checked by using resitance, this will only find a completely broken cable, which we don't have
A strand the size of hair will still give 0 ohms when checked for reistance
But it will not carry 100 amps
Same with dirty connectors, when you put 100 amps through them they burn and make new connectors
You have to load the circuit and measure for a voltage drop,
I am off out now, back this evening
No no no
Alright it's ok I'll be able to do that tomorrow so i could have someone to crank crank it while i do the voltage drop test
But now come to think of it the U1700 means that there's a lost connection between the BCM and ECU and the grounds are all not related as i understood your shared explanation of the DTC
I am going to do that but the question how is this going to bring back the communication between the BCM and ECU?
The battery is good and i even tried jump-start it as extra but it didn't work
Nope.
But I know how finicky Italian cars can be with earths so it's precautionary measure.
I've had Alfa's and Lancia's that would not start due to poor earths.
Alright noted gonna bring an extra wire to the engine and try jump start it simultaneously any other ideas?
Hello everyone i know it's sunday and everyone is chilling out so if someone is feeling like seeing that's what I did with no faults on the ECU BCM and TCM
And still won't start not to mention even with the extra battery based on the diagnostic tool the ecu is reading a drop to 10.3V upon cranking
The extra wire from battery -ve to the engine is doing nothing to help the connection of the battery -ve to the vehicle body. The quality of the battery -ve to body connection cannot be overstated Most -ve connections are made to the body metal.
And that's something i noticed during my active test not sure if you can hear the sound while the 1 and 2 one gets activated 3 and 4 both can't be activated
  • VID_20240310_115530.mp4
    46.3 MB
One more thing is voltage drop test on the engine is 0.27v and immediate drop to 0.12 and ECU is 0.15 and drops
