My fiat panda 100 HP from 2007 has a cooling problem when driving in a traffic jam.
The temperature reading climbs to red hot and only comes down by turning on the interior heating on max.
The cooler fan is not starting when temperature is above 90 degrees and the airco is switched on.
The radiator cooling fan works when connected to 12 volt directly.
When the temperature sensor is disconnected the radiator cooling fan is running.
So replacing the temperature sensor whill fix the problem?
Thanks for replying.
