Got to check over a 53 plate 8v Punto which recently has cut out on the owner. Come to a stop, and restart and the car and it drives fine. A local garage tried to claim ecu problem, but i think they were waffling. Car has only done it three times, and its rare when it happens, certainly rare enough that the car drives faultlessly otherwise.
I suspect crank sensor, voltage drop, flaky fuel pump or a relay.
But it has another problem which im wondering if its an electrical gremlin that might be at fault.
Press the brake pedal, and the warning light for blown bulb comes on, even though all brake lights work fine.
Put the main lights on and press brake pedal and the warning light doesnt come on, all bulbs operate as they should.
Is there a common fault for this?
