sponger
Member
Any advice greatly appreciated!
My Fiat Punto 80HLX 16v(year 2000) was idling a bit roughly when I pulled up after a 50km trip on open roads. Upon popping the bonnet there was a very thin stream of coolant coming out the top of the expansion tank cap.
I let it cool over-night. Checked fluid level - half way between low and high. Started it up. After 5 min the thermostsat opened sending water into the radiator and seemed to be circulating fine.
Took it for a run - fine at 80-100km but on crawling along for 5min at 40km the temp shot up. Pulled over, cut engine, ignition on - fan going until temp was back down - no coolant leak this time and level good.
Got home and have been tinkering to no avail.
Drained coolant - good condition. Flushed radiator - no rust flakes or brown water.
Connected it up and bled system.
Started it up without cap on. Idling smoothly. Surging in the expansion tank with some bubbles, but settled down as the fluid moved through. Bottom hose off radiator warm. It heated up above normal and fan didn't come on.(maybe I needed to wait a bit longer for fan cut-in)
Tested coolant temperature sensor by disconnecting - fan went on.
Could it be the water pump has failed? (has done 180,000km)
Could it be head gasket? ( But - no sludge in oil, no water in oil, no coolant loss)
I'm a bit clueless so any info appreciated.
