is it the one that runs down the cam cover ?
the wire for it runs down the belt cover
right i posted in tech talk with no reply so ill try here.
My engine keeps randomly misfiring whilest driving along.
The engine will be fine then suddenly misfire for about 20 seconds and then will clear itself and will be fine fine for a while until it happens again.
i took it on the motorway for along longish drive and it seemed to pretty much die completely after a while. But after leaving it on the drive for a couple of hours it seemed ok again.
Ive had a head gasket,water pump, termostat, oil filter, cambelt, new leads, plugs, coilpacks, lamda sensors and cat about 100 miles ago so i am baffled.
Any engine boffins got any advice as it would be greatly appriciated.
I have replaced the cam sensor and crank sensor today and still plays up.
L
Looks like after all that time and hundreds spent on parts, the part that was playing up was a £10 crank sensor!
FML!
