Air temperature - what are good values? I need to check them
Before you start the car it will be whatever Google says the temperature is for your town/village
If you mean here, on the surface, I don't see any oil.
with a cold engine it should be within a degree or so of google
normally if its out its just oil on it that can be cleaned off with a spray of brake cleaner
It was in oil, not that much,
You could get the belt put on the correct tooth, and it may run better, enough to live without the big bill.Yes I know it is a rare to get the belt done wrong. As I said above, maybe mechanic did something else wrong by mistake which affected the throttle response.
I got much better throttle response when I changed the fuel pump (lasted 1000-2000 miles). Also throttle response got better with injection cleaner (lasted 300 miles).
Head gasket is leaking oil too. Along with the pump and injectors they should be checked first.
I don't give up with the car! No matter how many troubles it may have.
Jockcl, I like your post here as I think our original poster has no great depth of knowledge and your solution - to remove and refurbish/overhaul the head - will almost certainly solve his problem (unless there's something we're not being told about or that is unknown at this time like a fuel pressure problem?).You could get the belt put on the correct tooth, and it may run better, enough to live without the big bill.
If the head gasket is leaking, the way to fix this is also cylinder head removal.
There is really no point looking for fault codes, as they are not going to fix a mechanical problem, the emission readings are probably slightly higher than normal, as some of the combustion is inefficient, as the valves are not fully closed when they are supposed to be.
Understanding the engine stroke, induction compression power exhaust, valves opening and closing at the wrong point in the cycle inevitably result in poor performance and valve/seat burning.
Taking the head off replacing seats and valves and refurbishing the head as nessesary, refitting with new gaskets and belt, will in my opinion fix the problems including the oil leak, and should feel like a new car.
But only of you choose the correct garage/mechanic that will do the job properly.
Cylinder head refurbishment it more involved with specific tools, and I would remove the head and send it away to a specialised engineering company to revalve/skim etc and then refit myself, this is what I have done in the past.
It is unfortunate that the first mechanic has caused all this, but the way to fix it is back to basics, fixing the damage that has happened, if you are keeping the car and have the money to fix it.
Although I think head removal is inevitable, I agree it would be worth knowing the compression readings, before and after the belt being set up correctly, which a good mechanic without being asked, would do anyway and want to confirm, the timing wants checked and set up before the head comes off anyway, so doing a compression test is only a few more minutes work, before the head removal is started.Jockcl, I like your post here as I think our original poster has no great depth of knowledge and your solution - to remove and refurbish/overhaul the head - will almost certainly solve his problem (unless there's something we're not being told about or that is unknown at this time like a fuel pressure problem?).
I've posted above about how I think the "head gasket leak" could probably do with a careful looking at (maybe do one of those gas tests on the coolant? and I'm a wee bit bothered though that a timing belt being just one - or even two - teeth out will cause burnt valves and/or seats? although running it like this for so many miles won't have helped and I agree that increased temperatures could be possible.
Incomplete combustion could be picked up on an exhaust gas analyser - which our OP is unlikely to have access to without extra cost - but it would probably show up in the fuel trims/learned values/O2 sensor readings? (he says he has MES).
Absolutely agree with you about finding a good engineering shop and giving them the head to recondition. Grinding in 16 - or even 8 - valves with my arthritic hands isn't on these days! To be honest I doubt if most DIY mechanics would do as good a job as a good machine shop, specializing in vehicle engines, can achieve.
I think this person's big problem, given what's been disclosed to us in posts above, will be to identify a competent mechanic to do the work?
I'd still like to know the compression readings, either, as PB suggests, with the engine as it stands right now, where more than anything else you would be looking for similar figures across all cylinders rather than how high the figure is, or, what they are if the belt is re-timed correctly and then compression tested. As a lot of the preparation work to access the belt is work that will have to be done before removing the head, if the compressions turned out good and the leak turns out to be cam cover and not head gasket, a lot of expense could be avoided? How about a cylinder leak test if valve condition was suspect?
Oh, and a very happy Easter to all.
I have had people ask me for advise, then go ask someone else and keep asking more, then waste money doing something someone said that was wrong, I must admit, I should be happy but I find it irritating when they come back and say I was right.
I used to work with a guy like that. Head full of theory, little practical experience, of anything.
Reading your stories is much the same as my experience, unfortunate some people are beyond help, but still you try to point them in the right direction, because you want to be a good guy and help them, only to feel like you would have been better off hitting your head against a brick wall, at lease then there would be a sensible reason for the headache that you have.I used to work with a guy like that. Head full of theory, little practical experience, of anything. He would theorise for days, or weeks, about any task or project, make his mind up, and then ask people for their opinion. Having made his mind up, he would keep asking more people until someone agreed with his idea, then reassured would go ahead and cock it up. Our boss was a bit like that too. Two stories spring to mind, not for here, perhaps the 'smile' thread.
It's interesting that some people don't understand the difference between ignition timing and valve timing, as if they were the same thing, and will go straight to a code reader for the solution, thankfully there are a few of us who can hopefully encourage people on to the correct path, wither they take it is another thing.
fuel trim is missing from some Fiat cars in MES
I couldn't find it on a 2011 1.2L panda although my Delphi software can read long and short trims fine
This interests me greatly as I've noticed that you get nothing actually labeled "Fuel trim" either short or long term with MES. The generic code reader embedded in my VCDS package reads fuel trims but, unfortunately refuses to "speak" to the Fiats! However I notice that "Lambda Sensor Integrator" and "Mixture Correction Learning Value" are often available with MES. Also they are quoted in %ages just as you would expect a fuel trim to be displayed. I suspect these are fuel trims but which is "long term" and which is "short term" I'm not certain. I'm "playing with them to see if I can get clarity. Anything you can contribute which might help me?
Jock
