Old 14-01-2020   #61
Re: 2004 Panda 1.1 active - Whining issue?
Okay. I’ll get it booked in for the next week or so if possible.
Gman88667733 is offline Reply With Quote Quote
Old 14-01-2020   #62
Sent my local garage an email for a quote a the soonest date possible that they could do it
Old 14-01-2020   #63
All booked for Thursday this week. £264 all in all. Not too bad, not the best. But at least then it’s done!
Old 14-01-2020   #64
You never know, if the water pump is the culprit for the loud squeal, at least changing it will sort that too? Kills two birds with one stone...
Old 14-01-2020   #65
My money is on the water pump. You don't have air con so it can't be the clutch and alternators only make nasty noises when they've seized up and raised the warning light.
DaveMcT is offline Reply With Quote Quote
Old 14-01-2020   #66
Okay. Well I suppose we will see on Thursday!. I assume a straight replacement would cure the issue immediately?
Old 14-01-2020   #67
Quote Originally Posted by DaveMcT View Post
probability favours slack belt.
mine needs adjusting every year or so. On a new belt. There's no tensioner on the models without aircon. New belts stretch and wear down a little. Settle down after a while. other car with old belt has never needs adjusting in 3 years but is just starting to slip
koalar is offline Reply With Quote Quote
Old 15-01-2020   #68
It definitely seems to crank a lot before starting first thing in the morning. After that it is instant. Hopefully spark plugs and a good service will help this a bit.
If not, the battery was put in at the start of 2015, so it’s about the normal age of one to start having issues, at least in my experience.
Old 15-01-2020   #69
Quote Originally Posted by koalar View Post
That's possible but they don't usually screech. I had a BMW bike that used a car type alternator and non-adjustable drive belt. To be fair that did make a racket one day, but the cause was alternator. The stator had corroded and split causing the rotor to foul. It went suddenly from from OK to not usable. When opened up, the belt was as fine with no signs of any slippage. The alternator was toast with a badly cracked case.
Old 15-01-2020   #70
Changed the oil and filter this evening before it goes in for the cam belt and water pump tomorrow.
After changing it all, I let it warm up a tad and then re-checked and the oil already looks a tad more brownish again. I suppose it needs a really good thrashing and then a couple of regular changes to clean it all up?
Looks like there is a slight old leak from the gearbox as well, but on a car this age, I’m not gonna think about that..!!! (I may be wrong though, gonna clean it up and keep an eye on it)
Old 15-01-2020   #71
Quote Originally Posted by Gman88667733 View Post
I suggest you buy a Forte advanced formula motor flush, add it to the oil and run the car for 30 minutes before changing the oil and filter.
The Forte brand is only sold to garages but you can buy it, from garages who sell through ebay/amazon.
It is the best stuff.
Jockcl500 is offline Reply With Quote Quote
Old 15-01-2020   #72
Since I’ve just changed the oil. Shall I add it to the next oil change in 1000 miles after I run it for a bit?
Old 15-01-2020   #73
Yes, you might as well do some miles in it first, then add the flush, run the engine for 30-40 minutes then drain, then change filter and oil.
It will work wonders cleaning the engine, I first used it in the early 90s and have used it ever since, much better than the offerings from motorparts shops.
Old 15-01-2020   #74
Wonderful.
Thanks for the suggestions, I’ll definitely do that.
After the cam belt and water pump tomorrow it’s going to get a good thrashing for a while to try and help too.
Likes Jockcl500 liked this post
Old 16-01-2020   #75
yes they do ? worse on start up and on I creasing revs.
Panda 2004 Panda Active Rust Problem? fayton10 Newbie Central 6 23-04-2019 18:25
(T) Panda 2004 1.1 active- tappy engine just201187 Panda 10 08-05-2014 14:07
(T) Fiat Panda 2004 Throttle Body Issue Jeeves28 Panda 6 18-06-2012 17:46
(T) Panda 2004 1.2 8v whining noise AAB1992 Panda 10 16-04-2012 17:22
Panda 2004 Panda 1.1 Active Dootson Members Motors 0 11-10-2011 23:34
