newbie fiat
- Aug 4, 2016
- 96
- 27
Hi All,
So i got a new car, i have done the dirty and defected away from Fiat. my trusty old 2005 plate panda has been replaced with a 1 year old hyundai i20.
i didn't want to get rid of the panda so left it on my drive, it has been sat there 10 days, i went to start it yesterday to let it run for a while as it will be put back into use as my partners car in about a year. and it started (very quickly as usual) but about 20 seconds later spluttered and died. i cannot get it to fire back up.
its not the battery i replaced it with a brand new duracell branded battery about 3 months ago and it has plenty of power when cranking. i have also run jump leads from my new car to give it a bit of extra juice and still nothing. i have done cranking for 10 seconds at a time and a minute at a time, it makes no difference it is like it is slightly catching as when you let the key off it splutters for a seconds and then stops.
i know fuel can go off but surely not after 10 days? it has over half a tank before anyone asks.
i have also today changed the spark plugs and it made no difference at all.
i have removed the air filter housing right back to the throttle body to rule out an air blockage.
so i have:
spark - yep
air - yep
fuel - ? should have
i had a similar issue with an old bike that had a carb that glazed over but that was after sitting for 6 months not 10 days. and these pandas have fuel injection right? but if 'feels' the same like its not getting enough fuel. is there anywhere to check for blockages?
any suggestions? is it just unhappy its been replaced?? :doh:
so i have:
spark - yep
air - yep
