A garage should know 100% if the throttle body is defective before ordering
There is a Throttle disgnostic test
You should not rely solely on the error codes, they point you in the right direction
The codes need to be manufacture specific, or better still model specific. Generic codes can be misleading
But you then need to confirm with further testing, especially when the parts are expensive
The engine computer can be told to position the throttle plate anywhere and it's position read back, The expected and actual then compaired
This is a Honda but the principles are the same
The plate should never be forced, with the ignition on
You shouldn't ever spray cleaner down here as per thousands of youtube videos
If it needs cleaning spray cleaner onto a cloth and wipe
