Here’s two photos I took showing inside the plenum (part of set on how to dismantle, which I will post sometime) - hard to see as dark green car! First shows passenger side with the ‘deeper’ portion which the drains are at the bottom of (below the bright blue bit). The other, you might just make out the air vent through into the car, behind the wiper motor. For water to reach up that far means a *lot* of water is trapped by the blocked drains.you can see the drain in the second photo, at the right, under the large, ridged plastic tube.
The blue plastic bits under the windscreen are the connections to the elements in the heated windscreen. The tube from bottom left of second photo is the screen wash pipe, disconnected from the scuttle cover to remove it.
These photos were taken before I cleaned the scuttle area - you can make out dead leaves and a silty layer, especially in the second shot.
