Old 12-07-2019   #1
Could use some advise with 1.3 multijet engine
I have recently purchased a fiat doblo 1.3.
Too start with there is a snapped glow plug in the head.
It starts fine and runs fine with no problems.
I had a fiat panda 1.3 multijet prior too this and the engine runs spot on too example.
I have an appointment for a mechanic too do a removal of the glow plug on the 22nd.
Which brings me too my actual question,
So the car runs fine, untill the engine fan comes on, the engine tone changes, it misfires on rev limiter if you hold the accelerator, and you get black smoke from exhaust from acceleration only when accelerating, dosnt smoke when reached speed, the smoke stinks like oil or diesel and it chokes u in the car(if im deiving around hard up too 3-4k rev each gear it really stinks, partner says it makes her get a head ache.
Also when the rev needle is coming back too idle it hangs at 1200rpm for 2seconds before slowly dropping back too idle.
The fan comes on some times even if the engine isnt fully heated up, never comes on cold, as soon as it turns off car runs normal again.
I sometimes turn the car off for 30 seconds and then the fan dosnt come back on for a while.
Would this be related too the glow plug?
Something too do with the dpf and glow plugs?
Im worried im going too get this fixed and there is a bigger problem.
Obviously rasy way too find out is too fix the glow plug, but would be great if any would has any knowledge on those symptoms related too the radiator and the glow plug.
Cial515 is offline Reply With Quote Quote
Old 12-07-2019   #2
Greece
Re: Could use some advise with 1.3 multijet engine
In a diesel engine the glow plug is only used to cold start ..it has nothing to do with how it runs ... I live in Crete and I have a diesel truck and I only use the glow plugs in winter time ....If you have fumes in the car maybe you have a leaking exhaust or your DPF needs regenerating ...have a look at this ...it seems to fit with your problems ...
https://www.rac.co.uk/drive/advice/e...ulate-filters/
isthisagoodidea is offline Reply With Quote Quote
Old 12-07-2019   #3
Apparently, i have read a few threads where people have said thst the glow plugs are used when the dpf is doing a regen, increasing fuel and using the glow plugs too heat the fuel hotter than the engine and thats why the engine fan comes on too keep engine temperature down while the exhaust stays ar a high temperature from the extra fuel burning, i did find slmething that said if a glow plug isnt working then the dpf wont regenerate.
Old 12-07-2019   #4
I think the fan coming on is a symptom and not the cause.
I don’t think I’m this instance the broken glow plug is to blame, the glow plug light would be flashing if it were.
I think there is something else going on here which is tripping the car to put the engine fan on. It sounds like it is significantly over fueling during these periods. Without knowing what the ecu is seeing you won’t work this out.
It need plugging in to see if there are any fault code stored. Also so see what happens at the moment the fan kicks in.
It’s worth noting the car won’t regen the DPF If it’s not warmed up fully, therefore this is your clue it’s not the car trying to regen.
Maker and voice behind the YouTube channel PuntoHowTo 10k subscribers canít be wrong
And now the owner of a shiny new PuntoHowTo Drivetribe
AndyRKett is offline Reply With Quote Quote
Old 12-07-2019   #5
Theres no fault codes other than glow plug failure, the glow plug light flashes when the car starts and turns off after 30 seconds.
The car does warm up properly sometimes, and maintans prpper engine temperature, the fan comes on generally at 40-50% (50% being middle of gauge)
I ran it for 400 miles the other day long trip.
And i do 100 miles a day.
The fan only comes on when a screw the car.
It can come on and stay on for ages even if temp drpps slightly on gauge, but then some times it turns off after 5 mins.
If i turn the engine off for 30 seconds it dosnt come back on where if i hadnt of turned it off it would stay on.
And like u said it over fuels while fan is on which causes misfiring and turbo whine on heavy load, and a stink of deisel.
Old 12-07-2019   #6
I have done alot of research on the matter and there is alot of places confirming that the glow plugs are used for a dpf regen not sure which 1 passive or active one is when u drive a long distance the other is when the car over fuels too rise the temperature.
I have also read and confirmed that when the car does the over fueling dpf regen the engine fan comes on too keep down the engine temperature while it uses the fuel too heat the dpf filter, this is where the glow plugs would be needed as the fuel is sprayed directly onto the plugs, if a plug is not working then the fuel for the cylinder wont reach the correct temperature and the regen will not complete and thus it will repeat over and over, ontop of the carbon being created because of the unburnt fuel.
Is what i gathered from alot of research, and it really makes sense.
Old 12-07-2019   #7
Well either you know all the answers in which case what was the point in you asking the question?
I still don’t think this has anything to do with the DPF regen.
This is why you need to plug it in, you can see if it is trying to regen, you can see if the DPF is blocked and needs to regen.
But it sounds like you’ve made up your mind...
Old 12-07-2019   #8
Im just saying what i have read, and clearly your just making speculations just as i am, so why dont you quit being patronising.
The other guy said glow plugs arnt used for dpf or when the car has been started, i was just clarifying what i have found.
I am also just trying too provide as much info from what i know as i can, i already told you that i connected it too a com, where does it sound like i already msde up my mind? It sounds like ive put alot of thought into something and im trying too bash heads with someone too work it out, but you clesrly want too start an arguement with your condescending attitude.
Old 12-07-2019   #9
Its also worth noting the car is an 07 plate and has only done 60k miles.
Old 12-07-2019   #10
I had read what you had already said, but you disregarded everything I said and kept banging on about what you’d already written. So you weren’t interest in what I had said, fair enough not my van or problem. I’m not going to waste time offering any more info.
With or without working glow plugs the car should not be pouring fuel out the exhaust..
The fact that you’ve just bought it, you bought it with a broken glow plug suggests it’s not been looked after well, and could have all sorts of problems.
You’ll find out if you’re right on the 22nd when you sort out the glow plug problem. Then you can come back and tell me ‘I told you so’ can’t you.
If you’re doing that sort of mileage then a simple DPF cleaning treatment wound aid the DPF cleaning process and the problems should all be solved.
Likes Cial515 liked this post
Old 13-07-2019   #11
Engine oil keep over filling can only imagine its deisel, engine oil change on again and overfull
Old 13-07-2019   #12
It could be the car is trying to regen. The oil only goes up if diesel is getting in it as you rightly point out.
I still think the glow plug will be a read herring.
It’s quite possible the DPF is blocked too, which would be a good reason for the previous owner to get shot of it, given how expensive they are.
There are also pressure sensors which work out how blocked the DPF is, if the sensors where faulty it can also cause the car to try and continually regen.
Likes isthisagoodidea liked this post
Old 14-07-2019   #13
Taken off inlet manifold and its fooking caked.
Well i cant get it off i just took the pipe off.
I bet thst pcv is blocked and when the raidtor kicks in its sucking all that **** through onto the cylinders.
Old 14-07-2019   #14
Australia
Just to be sure
Does your multijet use a DPF?
My GP 1.3 has also got a ton of crap in the intake manifold, unfortunately I didn't get around to cleaning it out over the weekend,
When I checked it last week, I was able get a long screwdriver in there but only got a small amount of rubbish out before it started to rain,
Anyway, hopefully I'll be able to let the manifold soak in a buckle of warm soapy degreaser this weekend, also I'll be using a long ish bottle brush to scrub the inside amongst other tools
llamallama is offline Reply With Quote Quote
Old 14-07-2019   #15
Australia
Couple pictures
ID:	201511   Click image for larger version
(G) Engine advise ... what would you do? dilleyj 500 (Classic) 20 16-08-2016 21:12
(T) Multijet Service advise cool_dood01 Panda 3 05-01-2014 18:41
(T) I think I need a new engine can anyone advise? legsdolan Multipla 1 03-06-2008 10:26
(G) Help & advise on fitting a engine???? thorne21 Ulysse 0 31-01-2006 20:36
New engine, advise needed :-( JaY (the original 1) FIAT Boo Archives 21 24-11-2003 15:44
