Yes, way too bright I think. Actually less safe. When blinded by any light, it is difficult to see past it, so can't react to anything ahead.Some of these new LED's are BRIGHT, don't you think? Also helps keep the hand brake cables free.
Most of the Audis I've driven, the hill hold lets go immediately the clutch is off the floor, often causing a roll back if the clutch is not brought up quickly. Missed the point there I think. Surprising the Seat is set differently.Talking about saving clutches. I've probably had a rant about this elsewhere but I really hate the hill hold on my new(ish) Ibiza. It holds on too long.
Salesmen mostly have no clue how the car works. When I test drove a Punto CVT auto August 2003, I had to explain to the sales manager how the system worked. Loved that car, like a modern DAF.Wonder if the salesmen are educating customers about these dry clutch, automated manual boxes. When I worked at the Daf garage - Dafs had a dry centrifugal clutch (quite pricey to renew) the boss insisted that every customer was given a lesson about how not to abuse it, which mostly consisted of :- when you stop apply the handbrake and take your foot off the accelerator pedal, then observing them and politely reminding them on an extended test drive. (The boss always liked a customer to have a nice long drive in the car before buying and sometimes I had to give up my demonstrator and go home in a trade in or on the bus so a potential customer could have the car overnight)
I started out in DAF garage, and my first two cars were DAFs, a 44, which sadly ran mostly on only 1½ cylinders, so was a bit slow, then 6 months later changed it for a 66. Did a lot of miles in that car.
The original XJ-S had this, but in an age of early electronics, was more trouble than it was useful. It would often warn of problems that did not exist, or fail to warn of real problems. But in this age of modern electronics and CANBus, such a system should be easy. We get a bit of this with warning messages to supplement the lights.What we need is a large orange light which illuminates when a warning is logged.
I suppose this is why some manufacturers are replacing dipsticks with sensors, to tell owners to do something before failure.
