Prepping cont...
I have taken a few pics of my seicento before starting, so the difference can be seen before/ after.
So screw driver in hand head out to your car, open the boot so that you can access the two screws holding the lights in place.
you might need to lift the boot seal up to get to it but they are pretty easy to get to.
Just unscrew each crew (2 for each light) and then tease the light out by lifting it up a little and giving it a pull - they come out easy enough.
Next you will see the electrical wiring that is connected to the lights
This is removed by just nipping it together and pulling - again it should come off easily enough.
now your lights are off your car you need to look at the back of them, and find two red clip type of things holding the actual light board in place.
just un-clip both and the lights will come out (remember which one cam from which, i left them in my boot on same side they came from). Also remember not to lose any parts, i.e screws, keep them safe.
now your left with your lights to spray, and gaps in your car where the lights came from.
Its up to you, but i decided to cover these wee holes as the weather looked a bit dodgy that day, and i didnt want some kids stuffing them with crisp wrappers and stuff.
I cut to size some bin liners, and masked them up over these holes so they were slightly weather reistant and wouldnt attract anyone to them.
Now thats done, close your boot, lock up and head back inside.
