Removing head
if you've disconnected the fuel supply, injection wiring , timing side engine mount, cambelt and headbolts you should be able the wriggle the head free.
Caution..it's relatively HEAVY , and you will be bent over to reach it..!!
mind your back..!!
before going too far with lifting it out check for anything still attached, AND check the orientation of the head gasket ( important for reassembly)
