Handbrake adjustment
A group of pics and hints for the 199 bodied puntos 2007/17
Basics before you start
Chock front wheels and put in 1st gear
KEEP handbrake applied
Climb in rear of car
The Large rear part of the central trim is only held in with clips.. so comes out easily
ToolFree
(clips shown in image)
Sit in central rear seat.. a foot in each footwell
Put a hand on one side of the Oddments tray at rear of the central trim
Pull and lift firmly ( you can put a flat hand either side of the tray)
ToolFree
Trim Removal 2
Once rear is unclipped
Lift quite high.. and front edge will uncouple from Gearchange area trim
Then you can thread the trim over the elevated handbrake
Cable Adjustment
THE Barrelnut..
Easiest moved with a
'Ratcheting Ringspanner' .. as access is a little restrictive
BUT..Before moving anything
1, look at the plate with the cable ends.. Ideally it should be Level
2, count the Clicks on the handbrake travel
