How To...
How To...?
The oil/diesel and engine components WILL get hot and ultimately have the potential to cause burns, please take care!
Points noted with a (*) should be repeated for best resuts
- Run engine until warm (Cooling fan cuts in and out twice)
- Remove sump plug (12mm Allen Key/Socket & Ratchet/Breaker Bar)
- Drain bad engine oil (Into the bucket)
- Remove Oil Filter (Using Water Pump Pliers/Grips, the filters can sometimes be really well stuck on making them impossible to undo by hand)
- Refit sump plug*
- Fit new oil filter*
- Remove oil filler cap (in the middle at the front)*
- Pour 3.9 litres of diesel into the engine through the engine oil filler.*
- Refit Oil Filler Cap*
- Run engine with no loads at all on idle for 30 mins*
- Turn off engine*
- Drain diesel from sump, remove filter and leave sump plug out for 30mins or so*
- Fit new oil filter (smear a little general purpose grease on the seal and tighten by hand)
- Refit sump plug and tighten to 49Nm (36.14 Lb-Ft)
- Pour 3.9 litres of Fiat (or equivelant) 10w40 fully synthetic engine oil into the through the engine oil filler.
- Replace engine oil filler cap
- Start engine and allow to warm up (cooling fan cut in and out twice)
- Stop engine, wait for 5-10 mins, to allow oil to settle in sump
- Check level with dipstick
- Top up oil as required
- Take her for a run revel in the silence and rest deep in the knowledge that it's all good for the next 4000-6000 miles
