Hey Guys and Girls!!
ive taken it upon myself to do a guide for the rear lights as i was a little :confused: of how to go about it, so figured this might help some of the less seasoned/complete n00b members on here.
to start with let me tell you about the different types of bulbs you will find in the rear cluster
5w Tail Bulb (207)
21w/5w 'Stop/Tail' Bulb (380)
21w Fog Bulb (382)
21w Reverse Bulb (382)
21w Orange Direction Indicator Bulb (581)
5w Tail Bulb
this bulb is located in the centre portion of the light cluster and is illuminated when side or dipped beam is operative.
This bulb is located in the upper portion of the light cluster the 'side' filament is illuminated as above and the 'stop' filament is illuminated when the brake is applied.
21w Fog Bulb
This bulb is located in the lower portion of the light cluster and is illuminated when the rear fogs are selected.
21w Reverse Bulb
This bulb is located in the inner most portion of the light cluster and is illuminated when reverse gear is selected.
This bulb is located in the outer most portion of the light cluster and is illuminated when direction indicators or hazards are operative. (note the staggered pins on the bulbs cap)
Next page: Tools & Parts
