yes i'm a bit rubbish at making it to meets/events.. i'll openly admit that.
That's a real shame, I have been very fortunate having the use of a garage and also worst case scenario I do not need the car for transport.
Is your shell really a lost cause.![]()
It's certainly easier to find a clean Sei than a Cinq now, even without a major rot problem where I live most of the Cinqs have been bounced off a few walls by now just due to age.
Body work is always something that puts me off a project due to the crazy amount it costs these days. One thing I'm really not very good at is painting, I just don't have the patience.![]()
I looked at the TJet and it does seem like a great option, however I'm seriously not keen to cut off the front panel, structual or not with out some serious modifications (think full cage to strut tops) it simply wouldn't be allowed here. I think I've seen atleast one with a complete front panel but it seems a bit tight.
Best of luck with it.![]()
Actually, the engine and turbo conversion was done with these two constrains in effect. However, it was very stresfull (having a hard deadline to make the thing run and being dependent on unpredictable wheather), I do not want to go through this again![]()
The poor thing had a bumpy life before I owned it, it's all patched up here and there, and whoever did that was far from a pro. So no, no confidence here that this can be saved. It is still in a running condition though.
Nearby where I used to live before, there was an old lady owning a mint condtion yellow sporinting, rarely but often enough used, looked like straight out of dealership, plus totally stock Had it been for sale I would buy it before she would even finish putting the ad upBut this is 1:1000 chance of finding something like this.
Well, you see, one clever person told me once - a good engine design or tune has to be tight, free space under the bonnet is a wasted resourceif you see what I mean. If Blu can run an airconditioned Sei with a turbo incl. IC and oil cooler, I am pretty sure there is a way to fit a t-jet into a Cinq nicely without disturbing the shell.
i use a renault clio williams filter on mine. Is probably the filter you seen fitted to turbo cento's, its much shorter than the stock item.
