What's made you not grumpy but not smile either today?
After having regretted buying it pretty much as soon as he got it last year, my dad has finally given up, and got rid of his Mazda 2. It's a shame really: a very nice little car, badly let down by poor quality ford components.
Unfortunately I'm now not feeling very well from all my exertions so I'm sitting quietly and doing this to recover! Anyone with more experience than me have anything else I should check that you can think of?
the mistake you made was having it regassed when it all worked find. Really as long as it’s working it should be left alone.
Likely what happened was when they put the vacuum on the system like putting your hand on the end of a hoover pipe all the pipes pulled in toward one another, and when they regassed it, it pushed them apart again, likely reseating old seals and o-rings which had formed nice seals, but now disturbed and old, probably cracked, they’re letting the gas out.
Normally people don’t get a system regassed until it’s out of gas in which case the pressure has dropped over time, the seals have probably gotten a bit more supple from the aircon cycling on and off, in your case the depressurised the system rapidly in minutes rather than months
Thanks Andy. I think you may well be correct. I have no experience with aircon. I've never worked with it back in the days I was "on the tools" and although I've read a lot about it I don't have any fault finding experience. I think your scenario above is quite likely. I'm waiting just now for a UV torch to arrive then I'm going to see if I can spot any leaks. If it needs much more than a seal or two replaced I'm tempt to simply do without it. This is the first car I've owned with aircon and the only thing I think I'll miss is it's ability to demist more rapidly in winter. Won't speed up the melting of ice which is much more of a problem up here and I can live without it on the one or two summer days when it is handy to have it to reduce temperatures.
One thing that "worries" me about aircon is that I thought the refrigerant is an atmospheric pollutant? I think the "new stuff" (R134) is less of a problem but still not harmless? I also observe that aircon system leakage is very common - Friends in the trade tell me it's a very common task to regas systems which are not working due to leakage - So why are we continuing to poison ourselves with these systems?
Like you Jock, I don't know much about Aircon, so I am probably wrong but I thought you had to put a tracer additive in the aircon to show up with a UV light?
My aircon is having the windows down and though some of my cars have it, I am not a fan even if regularly serviced, as one of my neighbours is still not 100% after catching legionaires disease working for a building firm removing aircon units from banks (I think that was all they were removing ;))
When I buy a car with aircon I always use one of those aircon "fumigator" sprays just in case.
Absolutely right Mike, tracer dye needs to have been added when the system was filled. I'm told though that this is common practice so I asked the garage that did it whether dye had been added and the, rather unhelpful, receptionist said maybe, sometimes they do and sometimes they don't and there would be no record he could consult to confirm. I thought about this for a while and then dropped in at both Steven's Honda garage and Kenny's Fiat workshop - both of which do aircon - Kenny has in fact just bought a beautiful shiny new machine!. They were both so busy they couldn't do anything for me immediately and Steven offered to let me use his UV lamp to look for leaks, however it was raining and I was in decent clothes so declined. He told me to buy a cheap "blacklight" torch off the likes of ebay/amazon and go looking for indications after dark - apparently these cheap torches do the job absolutely fine but are often not very bright hence the advice to do it after dark. So as there are already two cars in the "family fleet" with aircon and my boy's Astra is living on borrowed time as is his wife's Jazz so both may be replaced soon and the replacements will almost certainly have aircon, I thought buying a UV torch would be a good idea as they are under £10. No help of course if there's no dye in the system but a cheap enough addition to the toolbox in case they have. Of course it's all a bit academic because I don't have an air con machine or the license/training to use it so it'll have to go to a workshop for recharging but this way I'll know for sure that if they come back saying "it needs a condenser", or whatever, then that is in fact the problem. although I'd have complete trust in either of the afore mentioned garages not to rip me off.
Driving with the window open is how I would normally choose to go but Mrs J insists on being hermetically sealed in on all but the very hottest of days!
Our new juke seem to lose the gas after about two and a half years. Thought it must be faulty, took it back to nissan as it's still under warranty, and no, just needed a refill, nissan recommend that every 2 years, therefore not under warranty.
Makes me feel not so bad my citroen only held the gas for 4 years, though I see it leaks very slightly around the compresser join in the case. Recharge once every 4 years seems ok though
See the grumpy thread,
Got the hot water tank out and outside without too many issues. Replaced the immersion heater ready for the electricians who are coming friiday to finish our solar installation and to add a solar boost thing to ensure hot water gets priority. Only one very big bucket of scale removed. It all wnet back OK and only one small ;leak from the new immersion heater, easily fixed with no big issues. No electrical problems either. All back an dworking and I cna still just about move and have a day to recover in bed before they arrive Friday.
Lucky down here we don't suffer from limescale, probably just the radon gas from all the granite on the moors the water runs off:)
Just a quick point to note. The dye is generally the last thing to leak out, usually it’s the heaviest thing in the system and so when the pressure is going down lighter elements like the gas leak out first, maybe any oil that’s in the area and then some dye might get forced out, it’s not uncommon to not be able to easily find the dye. Also good or bad UV light, if you have the option do it in the dark it will make finding the leak a million times easier.
If it does ultimately run out of gas you can buy O-ring sets relatively cheaply and these days it’s much easier to replace the o-rings yourself, but…
Never work in a pit under a car with leaky aircon
Never lay under a car with leaky aircon or start disconnecting pipes. The gas is an asphyxiant it displaces breathable air and can suffocate you, it’s heavier than air so can fill a work pit leaving no breathable air. It’s not poisonous and so you don’t really get any symptoms to warn you, your body will think it’s breathing normally.
That in mind it’s really not any more dangerous that anything else on a car and a very useful skill to learn.
As for two year aircon charges also mentioned on here, that’s crap and irresponsible to of the manufacturers to make a car that blatantly leaks ?1kg of gas every two years! Ridiculous. I think my mk2 Punto had an aircon charge once in its whole life and I sold it at 12 years old and 120k miles.
Touch wood my golf is now on 7 years and my wife’s mini which uses the more expensive 1234y is on 5 years without neither needing a recharge.
Thanks for that information Andy, not being a fan of Aircon I didn't know about about it's heavier than air risks in a pit or similar. Though I try and avoid working in a pit as once a car caught fire whilst bending an exhaust (with I might add a "blind" fire watcher) under a ramp, the thought of the same event trapped in a pit doesn't bear thinking of!
I had heard of "servicing" aircon every couple of years, but had thought of it more a visual check along with the anti bacterial spray inside the cabin for the reason I mentioned earlier. Would you say that is effective or a good idea if no apparent issues? I confess I am speaking from ignorance:)
Other than my Swift which had been in a front end prang and a pipe behind the front bumper sprang a leak..I've not had a car leak A.C. gas ever.
We never touched the climate control on the wife's eventually 12 year old Micra (we had it 6 years) and that worked fine until we sold it.
The Citroën currently works as it did new after 5 years.
Out of interest are the people whose systems need regassing also the people who never press AC unless it is 25 degrees out? Seem to recall all the seals dry out if you don't use it..and the one constant in my cars is the system is always on..as I did some measurements years ago and it made the square root of bugger all difference unless it was a very hot day in terms of economy and it keeps the windows clear without the temperature set to furnace.
The only car in the past that I have been in where the aircon was extremely cold/efficient was my accountants grey import Lexus Saurer 400 coupe, a rare car at the time, you could describe it as sitting in an ice box.
I recall the cars errors came up on the dash in Japanese, in the end he paid a Japanese student to translate it......the screen washer bottle was empty!:)
If you set the Citroën to minimum then it's putting your hand next to the vents of a freezer..but that's not actually comfortable.
My dad being of a certain age used to only stick the AC on on fully cold in his 307 if he used it..but he didn't like how cold it was so also used it on window and feet setting with the result it used to freeze the inside of the window 😂.
In general if you set the cars I've had at cold...they would be but I tend to run round with the climate pack set at about 22-23 in winter and 20-21 in summer, AC on and it'll sort it. In theory you should set it once but it never quite seems to account for sunlight heating or heat loss from the glass quite right.
I have a 2012 C3 Picasso I paid £300 for, good run about after a few issues sorted but electro magnetic Aircon pump pulley in/op, I have yet to look at why.
the old adage, if it ain’t broke don’t fix it. if the aircon is working fine it’s usually far better to leave it alone than mess about with it. If you keep it switched on all the time bacteria shouldn’t build up but if you turn it on and off what happens is the moister that would normally collect and drip off the evaporator stops flowing, stays on the evaporator and stars growing nasty mould and bacteria in the water droplets kinda like the mould you get in a washing machine or a turned off fridge. That’s when it starts to smell. Yes the aircon Is switched off when the car is not moving, but then hot damp air isn’t being blown over the cold alloy evaporator right next to a hot heater for when the engine is running. The bacteria doesn’t tend to build up on a car that’s not moving and is a product of the aircon being turned on and off but left off while the car is in use.
so turn it on, leave it on and it should never need any sort of service or interference
To be fair all cars should have icy cold aircon, sometimes let down by a bad heater design that lets warm air mix with the cold, but mainly having lots of glass with no UV filtering and cheap cars with little to no insulation tend feel like they have very poor aircon
something like a Japanese import Lexus, probably had uv protected and polarised glass as well a thick sound deadening and insulation
Probably worth pressure testing it before you bother, may be it's sprung a leak in the past dropped below minimum operating pressure and the safety measures have kicked in and deactivated the clutch.
If it's been like that for years (pretty likely given the price you bought car for cheap with issues..no one spends money on older Citroëns until they are beside the road bonnet up generally then complain they are unreliable..) then there's a good chance the pump is seized and all the seals are trashed at which point far more bother than it's worth on a 300 quid car.
I’ve seen super cheap cars like this where whole pipes or parts of the aircon system are missing and what remains is full of water and other nasties.
I agree with everything Steven said likely the gas has all leaked out anyone if it’s not been looked after, likely that the clutch Won’t kick in, without anygas, if moisture had gotten in then the dryer/receiver might need replacing, all the seals would benefit from replacing or at least reseating.
you may also find if the system has been non functional for a long time and moisture has gotten in, rust can form on parts of the compressor, which is fine till you put it back into service and then within a few months the worn off bits of rust act like sand paper circulating around the system and destroying the pump, so it seems like all is ok at first, then bad noises start
It was an ex taxi with 220k now showing on the speedo, once I cleaned out the DPF and told the ECU it was new plus EGR stuff etc. as well for £300 it has been a good buy, £30 year tax, good on fuel , having said all that, it will probably blow up tomorrow;)
I seem to recall on one of my diagnostic checks it gave the Aircon pressure, I might be wrong but it seemed acceptable at the time, all the correct lights, switches etc. seemed to be correct, just no reaction at the pump pulley, in fairness I haven't delved to deeply as pump low down on the engine and wiring plug dissapears into the engine loom. It may be a relay but I haven't found a wiring circuit diagram yet.
Hopefully the bloke will have maintained it like his lively hood depended on it, and as result most of the dv6 issues would have been fixed long before 220k...or have been taken care of by not being used round the doors. They can be strong..but need the right usage and care.
Some of us do, mine's a 2011, still looks good and quick enough to have some fun. It gets whatever it needs.
Indeed some..but most follow a similar route to old Fiat's, only in the dealer network for 3 years while on finance. Depreciate to throwaway money quickly, serviced badly after if at all after and aim for the scrapyard by about 10-12.
Not really a comment on the cars themselves just self fulfilling unreliability prophecy... I didn't want to spend money because it's cheap..and now it's become expensive..so punt to the next poor sod.
Now they do hold on to their money better may well be you see more older ones looked after. We're in a bizzare world at the moment where to replace a Citroën we bought brand new for 14.5k with a similar used one is still somewhere over 9k at 5 years old. It makes maintenance more palatable, given the original expected future value for it on 2020 at 3 years old was less than 7 grand.
