So why didn't you do "Dad's" as well then? - it was parked next to yours on the drive!!!!!!!!!!!!!!
Boasted to my neighbour welding up his MR2 that my teapot was going great. Hopped in, went 300 yards down the road, tried to change gear, the clutch wouldn't release and stuck fast. So stuck the slave cylinder exploded. Had to be pushed back home by MR2 man.![]()
that would be greatJonboy, just make a start with dismanteling the engine when your confident that you have the ability to rebuild it. Ill start scanning the tipo original fiat workshop manual tonight after work hours. Worst case i have some delta integrale manuals in pdf to make things work. Ill PB you an url when i'm done where you can down them, cam timing is to be found in those manuals.
engine will be about 84000 miles, was missing teeth of timimg belt when i bought car so just ripped the engine out and dropped another in, its not run for about 2 and a half years. its been covered up but some water has got in, should of left the spark plugs in:bang:. dont think the pistons are to bad think they just need a good clean up and maybe some new rings, ill post a picture of them when i've rubbed them up.Well i don't know what the number is for but i'll check my engine later tonight, it might be common for the sedici. It looks like the both pistons which are at TDC are damaged and the other two look like they have seen some water. What milage does the engine have. (km's even easyer).
The 1756 engine has the same size pistons but has a longer skirt on them 25mm in comperison to 15,7 mm in the sedici engine, all the rest is the same. So if the sedici pistons are impossible to find use those and skim the skirt (have it done). The engine is globally the same but the skirts on the sedici are shorter because of the bigger radius the cranck makes when rotating. Am i right here ?
Try to search for bore 84 make fiat and see if there is anything to your liking.
http://www.motorenteile.mahle.com/eLIZA/app/welcome?locale=en
not sure about the valves yet not got them out, but will have a look.hey thats a mess.
Hope 2 things
1. You know which main bearing cap goes on which main and which way round.
2. Same as above regarding the big end caps.
What state are the valves in?
We'll new pistons for you -which you cant get any more, a few new valves. Did the belt slip, any missing teeth. Never been a better time to make a better engine or put a turbo unit in it!!
