no hammerite smooth from halfraudsi painted my drums just because they didnt look right. did you use proper caliper paint for them.
lol yh i started a thread and everyone prefered there own thing to be faira heard the hammerite doesnt last as long as proper caliper paint cz a was gonna use it.
Question: Whats the pcd and the offset?
Answer: Hi There, PCD (Bolt Pattern) is 4 x 100 Offset is 35..38 (although this can be adjusted with spacers to fit cars with different offset) I bought the wheels to directly fit a Toyota MR2 Mk1
^ (copy and pasted from ebay)
would these fit, if not what would have to be done to make it possible?
i know i would need wobbly bolts, anything else?
the mr2 w2o 91 to 99 wnt fit because they have 5 bolt holes bt a punto only has 4. i dont know wheather thts wt u were lookin for.
i think tht spellin might be wrong dunno
Bump... any one know if these would fitQuestion: Whats the pcd and the offset?
i have standard fiat alloys but want aftermarket onesMost fiats are 99mm PCD. Some are 100 and need special washers to fit to a 98 hub.
Why not just fit some Punto alloys. With the Government's scrappage scheme there are loads in the breakers and they WILL fit the hub. Some will need a spacer plate and longer bolts.
The original steel wheel bolts are too short for alloys so you need the alloy bolts as well. A good breaker will throw them in free.
Wheels can be stove enamelled from about £25 a wheel.
Another point is that your car could have been originally built with Punto alloys so its still unmodified for insurance purposes.
