AeroMad
Quote from the Manual here (Page8):
"If the warning light (Car with Lock going through it) turns on, this means that the system is running a self test (for example for a voltage drop. At the first stop turn the ignition key to STOP(Off) and then back to MAR (On); if no faliure is detected, warning light will not come on."
"If the warning light stays on, repeat the procedure described previously leaving the key at STOP for over 30 seconds. Should the inconvenience persist, contact a Fiat Dealership."
"If the warning light stays on this means that the CODE(Immobiliser code in the key) has not been recognised. In this case the key should be moved to the STOP position and then back to MAR; if the lock continues, possibly try again with the other keys provided with the car. If it is still not possible to start the car, follow the instructions given in section "In an emergency" and then contact a Fiat Dealership."
