ruinin
Established member
I would like to get my valve adjustment done, but what I don't understand from a different thread, varesecrazy writes:
"If adjustments are necessary ( shimmed out) TRICKY = it could be £100 /£150".
I called a Fiat garage in the city where I live, asked about the price of the valve adjustment and they said if adjustment is necessary, they cannot trim anything, they have to replace shims. I later found out the shims cost almost nothing, about two UK pounds for one shim. So what makes the adjustment so expensive? The mechanic told me that people don't have this adjustment done in general bc it is too expensive...
checking the adjustment, half an hour work, then replacing cheap shims will last several hours? makes no sense.
