Technical vacuum advance unit
pound
My 1989 Panda 1000CL vacuum advance unit has failed. And hell I cant find one for a reasonable price. £27.04 + postage on top at these guys:
shop4parts
Any suggestions - nothing on ebay at the moment :(
Maby it will help:
tipo tempra{1.4 1.6} uno{1.3 1.5} ritmo regata{1.3 1.5} etc unit will work{ cars without digiplex ignition with distributor in the engine block}, it is the same part but with different part number because the vacuum delivering pipe goes at different angle than in panda .I have one under the bonnet of my panda.
Maby it will help:
The ones off these other vehicles may look the same, and fit, but may give different results. Like the mechanical advance inside the distributor is matched to the engine, so is the vac unit. If getting one off a scrappy, it probably needs to be from same engine spec as yours. Unless any identification codes are the same.
Wrong advance can lead to hot running, poor performance, or holed pistons.
