v8 / 8 valve ... what??
pinkdolphin113
okay, so i've been reading up on the whole v4, v6, v8, v12 and v16 part of the engine. now i understand that that means there 8 cylinders (2 sets of 4) on the engine.
how ever, i see 8 valve and 16 valve engines...does v8 mean 8 valves? or is it something else?
thanks.
a V8 engine is an engine in a V shape an engine that says 8v or 16 v is not in a V shape and also V engines have a distinct purr! fiat made an 8V V8 engine
http://auto.howstuffworks.com/engine4.htm
thats an 8 valve 4 cylinder engine
you see the 4 pistons at the bottom(so 4 cylinder)
and at the top 2 valves per cylinder
if it was a 16 valve there would be 4 per cyclinder
then it scales up
like a 24v V6 engine,still 4 valves per cylinder like a 16v 4 cylinder
An internal combustion engine functions by inducting a mixture of air and petrol (or diesel) into a cylinder, sealing it then compressing it before igniting it with a spark. The resulting explosion, really a very fast burn, pushes the piston down which provides the power to move the car. In its simplest form, there would be one inlet valve and one exhaust valve.
Effectively, the more air and petrol you put in to the cylinder the bigger the bang and the faster the car goes.
The way you do this is by putting as much as you can through the inlet valve. Once you get to the stage where you can get no more in because of the diameter of the valve you have to put in a bigger one; then a bigger one and so on until you can't get a bigger valve into the cylinder head because of the diameter of the cylinder. Not forgetting of course, that if you put a lot of air and petrol in, that's a lot of exhaust gas which needs to be evacuated, so, a bigger exhaust valve is the order of the day. When you get to the stage where you can't get two bigger valves in, you simply put four smaller ones in.
You could even get five even smaller ones (Audi, Yamaha) in as four or five smaller valves take up less space than two big'uns.
'fraid that went on a bit, as do most of my replies. Hope it may have answered a few questions. If not, well I had nothing else to do.
http://www.autozine.org/Classiccar/html/Fiat/8V.html
"Fiat 8V was the only V8 model the Italian giant car maker ever produced. Interestingly, it was named "8V" instead of "V8" because Fiat thought the latter were a registered trademark of Ford, which was not true"
So definitely a fail
I read that as 8 valve V8...which as far as I'm aware is an engineering impossibility which is why I questioned it but now I know (y)
I think Buzz has come up with the best answer so far :cool:
Who?
I dont... there LOADS of 16v V8's around lol! :p
Almost every V8 made in the US has only 16 valves. As did Rolls Royce and Bentley.
Not an impossibility, two strokes only have one valve per cylinder.
SPD
I don't think reed valves are quite the same thing. While we're on the subject Evinrude make a V6 6v 2 stroke 3.5 litre outboard that punts out 300hp.
SPD
Prior to the two stroke reed valve system, two stroke engines had no valves at all and relied on piston ports to control intake (and exhaust). If I remember rightly, it was Yamaha who were one of the first to use reed valves on a road bike and they named it 'Torque Induction'.
As an aside, I think it was Suzuki that used an alternative system called 'disc valves' to control induction on their two stroke motorcycles.
