Uno  Uno Turbo - Build Thread!
Hi there guys
Note been here for a while, but back in the Uno fold!
So, here is what i brought, a Uno 60 with a Punto GT engine conversion.
I wasn't really looking for an Uno again, however this was absoultey mint! Never seen a welder, been waxoled religiously, was just too good to pass up...
Anyway, here are a few of pics of from the previous owner.
Pre conversion
50416149472_18675391da_k.jpg17436277_10155175486061133_4067005824794538346_o
50415986051_73e21e0c4d_k.jpg17505291_10155175486056133_4403625514477524486_o
and a pic of the engine and conversion, nice low mile 33k engine and box from a crashed GT.
50415986306_cfcfa2d6e6_k.jpg33k miles
Few pics showing how clean the chassis leg's were!
50415296348_b4b3597169_k.jpg17545151_10155202021251133_9017383826645831261_o
50415986006_93df6b76c4_k.jpg17546709_10155202021271133_6284075121915445096_o
And a few of the conversion parts
Turbo Loom
50415985796_343f3fe07c_k.jpg17620464_10155201643396133_4410026011063445848_o
Turbo rack and brake servo
50415295898_2fc97e3d8f_k.jpg18700503_10155380928311133_6638692855718458288_o
50415985691_eadf4fb12d_k.jpg17855263_10155236761556133_5650748184055805630_o
GT Brakes and Turbo Hubs
50415985441_07dd01002f_b.jpg20915246_10155697191151133_5836332418976815106_n
50416148932_bccc935427_b.jpg21231073_10155750781666133_5455011764000393731_n
50415295753_22558e0b5b_b.jpg29790695_10156399968121133_5956662486089564548_n
New valve guides and stem seals
50416148872_c447b8b589_b.jpg35345776_10156602637951133_1324371981973323776_n
And a few of the pics of how i brought it..
50416122677_11ab4b259c_b.jpgIMG_4290
50415269643_cc3f673f92_b.jpgIMG_4288
50415269633_94bfc12c9a_b.jpgIMG_4289
50415959366_4d22b5b12e_b.jpgIMG_4291
When i brought it, it had a few issues i wanted to sort, firstly a really unstable idle, and a few bits that i wanted to re-do to my spec. Firstly the fuel system...
This was how it come
50415957831_fedb803c1b_b.jpgIMG_4374
50415269593_6ba8e16033_c.jpgIMG_4350
Firstly, i got a Metal Mk2 Uno Turbo fuel rail rather than the plastic GT one.
50415269548_2d90bb6895_c.jpgIMG_4380
50415268038_8c6413083e_b.jpgIMG_4372
So, cut off the fittings and TIG welded some AN6 Fittings on
50415959306_37c5d7964c_c.jpgIMG_4381
50416121037_55cf8f2a87_c.jpgIMG_4445
I also changed out all the lines to 8mm nylon front to back
50415959036_ea204595a8_c.jpgIMG_4457
Next i needed to make up a mount for the FPR
50416120972_b9eecd5b61_c.jpgIMG_4450
50416122327_713c3f6473_c.jpgIMG_4452
Next up made up the lines and fitted
50415269193_07317bb691_c.jpgIMG_4462
50416121572_013387e176_c.jpgIMG_4862
50415268418_ffdd2eb4cc_c.jpgIMG_4864
50415268468_71faa3d3fb_b.jpgIMG_4778
At the fuel tank end i replaced the original turbo tank with a baffled tank. The days of an undertank fuel pump are gone what with the invent of high flowing in-tank pumps
Old tank
50415269153_b36da02101_c.jpgIMG_4569
Old vs new pump
50415958971_2099d4c8a1_c.jpgIMG_4570
And fitted
50416122217_a2a1c07b57_c.jpgIMG_4587
Next up was sorting a pet hate of mine, bad wiring...
Stuff like this
50415269573_80506f436b_c.jpgIMG_4373
50415957791_80a8c9f475_b.jpgIMG_4377
50415957801_54aebda07e_b.jpgIMG_4376
A few before and afters:
50416121142_6562f768dd_c.jpgIMG_4389
50415269513_0ea29b3334_b.jpgIMG_4388
and after
50415267963_a6cdb7e92c_c.jpgIMG_4392
Drivers side
Before
50416121032_c3e4483f05_c.jpgIMG_4446
After
50415957661_4f52656cc7_c.jpgIMG_4447
Next up was the engine loom, i wanted to clean up the engine bay, move the ECU and relays into the car and make it look clearner
Here was the loom before
50416122562_25a8cb40f1_b.jpgIMG_4395
50415959211_7619d0ef1c_b.jpgIMG_4396
Making a template of the original loom
50415269178_4169ec5c12_c.jpgIMG_4478
Mid making
All new wires
50415959001_3dca126d89_c.jpgIMG_4482 (Medium)
And done, lovely MIL spec connectors
50416120707_977dae8d2a_c.jpgIMG_4624
50415958841_117eb4b7f1_c.jpgIMG_4625
50415958836_9d2ecb4124_c.jpgIMG_4626
ECU, Relays, Fuses, and Bar sensor moved into the car.
This was the location when i brought the car.
50415424883_5230a3fe4a_b.jpg21231651_10155750779106133_4228195100090642726_n
And after, tucked under the dash.
50415958891_894c0e3204_c.jpgIMG_4610
50415267543_1d92fa61de_b.jpgIMG_4611
50415269068_90a6c7cf91_b.jpgIMG_4612
Sorted a few other bits such as this massive leak..
50415269523_66a2e66b64_c.jpgIMG_4384
And cut and welded smooth
50415959286_b1ff94f5d5_b.jpgIMG_4387
Also fitted central locking
50415958806_11fe0f2f25_c.jpgIMG_4645
50416122072_317766308b_c.jpgIMG_4650
50415958786_ce8a1189eb_b.jpgIMG_4646
Next up was sorting the lack of any kind of ducting on the intercooler and oil cooler, seen the difference a well ducted design could make on my Supra so figured i would fabricate some up.
Before, you can see the gaps all around where the air would escape
50416327782_a69965fe83_k.jpgIMG_4659
50415958761_6ee478069b_b.jpgIMG_4660
TIG'd up some ducts from aluminium
50415958726_d661fa56d1_b.jpgIMG_4667
50415957311_276de5b368_b.jpgIMG_4669
50415268978_431ee3a93d_b.jpgIMG_4668
Oil cooler
50415957286_031360200d_b.jpgIMG_4688
50415958666_eb41ce428a_b.jpgIMG_4685
New ducts and stainless hardware
50416121977_3871c4a5ee_c.jpgIMG_4689
50415958621_6fceea9529_c.jpgIMG_4691
50415958641_363e33fafd_c.jpgIMG_4690
50415958616_d0864353e3_b.jpgIMG_4693
Much better, now the cooler will do something!
50415957221_164339ea1f_b.jpgIMG_4779
Next up i wanted to make an AFM mount as it was just floating about, so...
50416121872_298ab3417a_c.jpgIMG_4707
Picks up on original mounts
50416121867_d1f4dcaa03_b.jpgIMG_4709
Also made up a cable mount
50416121852_b7019608cc_c.jpgIMG_4714
Also TIG'd up some new boost pipes to replace the original mishmash, also changed the filter to a stock air filter housing
Before
Making the new pipes up
50415957271_e8a650c692_c.jpgIMG_4698
ICV Spout
50416121927_a866c4a3ed_c.jpgIMG_4700
Swage the ends
50415268878_3d1e3d5508_c.jpgIMG_4703
50415268883_37ef64e12b_c.jpgIMG_4701
Fitted and done
50416121887_27b30e25e7_c.jpgIMG_4705
50415268828_a2f09658fd_c.jpgIMG_4706
50415267473_8cb23fcc2d_b.jpgIMG_4771
50416121777_0a7ceb02c4_b.jpgIMG_4775
50415268658_20061b51ec_b.jpgIMG_4777
Last job was fitting a light grill i got from italy along with Mk2 Sideskirts
50415268778_0d7633fd81_b.jpgIMG_4718
Next a nice simple thing, getting rid of my old knob as it was a bit blue for me..
50415957201_35285bc208_c.jpgIMG_5249
Nice little carbon number to replace it
50416121487_447991e97b_b.jpgIMG_5251
Next up was to put a proper Turbo boot on, this is the one that come with the car, looked great but prefered the turbo look
50416265586_00ccf5ce03_b.jpgIMG_5385
Weight of the stock metal boot
50416265536_19478a41e6_b.jpgIMG_5387
Weight of the new fibreglass turbo boot
50415574593_7278500066_b.jpgIMG_5388
And fitted
50416265561_cb70e4e043_b.jpgIMG_5389
50415574543_d23f0b08a8_b.jpgIMG_5403
Much better!
Next up was fitting my new boost controller, using the original clock location
50415958091_e10b511c01_c.jpgIMG_5404
50415268323_9898451b14_b.jpgIMG_5407
50415267418_95c29d75fa_b.jpgIMG_5410
Perfect fit!
I still wanted the original digital dash boost gauge to work, so i used the original MAP from the Uno Turbo ECu with a 5V step down power source mounted to the back of the clocks
50415958021_6ba311512d_c.jpgIMG_5455
Cut down
50415958011_ab3c9b16cc_c.jpgIMG_5456
And fitted
50415268183_81f5ab5429_b.jpgIMG_5482
50415957926_ef5be01992_b.jpgIMG_5483
Next thing to replace was the original black carpet with a red turbo item
50416121457_0cc68b6a86_b.jpgIMG_5437
Stripped out and cleaned the floor and protected
50416121437_eef2390ae2_b.jpgIMG_5438
50415267393_579d5ed860_b.jpgIMG_5440
50415615778_f74ba23d77_c.jpgIMG_5441
50416121402_9a76b1aa42_c.jpgIMG_5443
50416121382_33269f9303_b.jpgIMG_5445
50415957126_656ced3b68_b.jpgIMG_5446
Above you can see the original sills, the previous owner regularly waxoyld it and you can tell... no rust!
Now thats a carpet!
50415268058_c9cc231272_h.jpg777B7CDF-CDB2-4ADE-AE3A-96D24E52882F
While fitting the carpet i decided to add the turbo door and rear cards along with electric windows.
This is how the cards were before...
50416121297_af61cf9806_b.jpgIMG_5562
First up was putting relays in each door, made up a little aluminium mount
50416121287_75625b6b81_b.jpgIMG_5586
All fitted and wired up
50416120487_404aeb2594_c.jpgIMG_5559
Turbo door cards, electric motors and rear cards fitted
50415957891_a4c9d6cf18_b.jpgIMG_5594
50416121262_1650edf452_b.jpgIMG_5597
50415957886_5166cb2b1e_b.jpgIMG_5596
50415268073_1f1b704bec_b.jpgIMG_5598
50415957091_ec86065f21_b.jpgIMG_5599
And also fit my new clutch slave as the old one started leaking.. new braided stainless line too...
50416120502_1d037888ea_c.jpgIMG_5535
50416121307_083bca5aab_c.jpgIMG_5538
50415957966_a1564cf1e0_c.jpgIMG_5471
First the Speedo stopped working! Looks like the original Sharp optical sensor had started to break down
49538607717_3598ba4891_b.jpgIMG_5613
So replaced with a modern sensor, was very tricky!
49537888013_8ccfbb4af7_h.jpgimage1
Next up was a wheel change, got some Strada 14" Speedlines
49537888123_9f28f07d09_c.jpgIMG_5876
49537888083_9e6ca52bb4_c.jpgIMG_5875
This is how they come back
49538607677_4a7bcf64c4_h.jpgCF8F002E-745E-4518-938B-E3B708DCDA21
49537888733_16d4391381_b.jpgIMG_6094
Next up was to change the rad, i want a 50/50 split with the intercooler. I looked at a few options but in the end went with a 4 core 60mm thick Civic radiator.
So, here goes...
Stock rad
49538607892_b3fb1007ec_b.jpgIMG_5946
As the radiator was rotated 90 degrees i needed to split the radiator flow path, so gap cut
49537888343_fda0644a7d_c.jpgIMG_5975
Plate slid into the gap
49538607967_cfab86fe74_c.jpgIMG_5976
Welded up
49538608087_e52529815a_c.jpgIMG_5980
Temp switch bung welded in
49538607702_5fe3442e11_h.jpgDF934471-16FE-4D3E-80BD-D6D6CB60A458
Mount added to top to connect to slam pannel
49538607652_d2c8a2c1aa_h.jpgBCEBC23B-880A-44EB-B9C1-AAC557611DE2
Bottom rad hose fits perfect
49538383126_e276cda697_b.jpgIMG_5991
Top rad hose needs some work
49538608162_ec9ae5aeb7_b.jpgIMG_5992
Made a custom top alloy rad hose and added an outlet to the top of the rad
49538383436_84443acf4b_c.jpgIMG_6123
As the rad was moved right to the passenger side i needed some very small trimming and wanted to push all the air through the rad
Trimmed up
49537888513_ceffd65b60_c.jpgIMG_5993
TIG welded in place
49538383191_f52c0ee1f0_c.jpgIMG_5998
ground back
49538608217_0d4eedee8b_c.jpgIMG_5997
Primered
49538608282_1113088976_c.jpgIMG_6002
and painted
49538383286_b17cb43ffd_c.jpgIMG_6018
Radiator wiring done, all contained so a direct plug in connection
49537888773_c379e82df5_c.jpgIMG_6116
And all completed!
49538608557_77c8b0bb67_c.jpgIMG_6136
49538608532_7665b55d4c_b.jpgIMG_6133
49538608502_859396b1cd_b.jpgIMG_6132
49537888823_362bd17e71_b.jpgIMG_6131
Here you can see the area left for the intercooler
49537888928_6d4baa4a6f_b.jpgIMG_6139
Last mod was a little anti social...
Welded a T into the downpipe
49538383321_c1662ffcd0_c.jpgIMG_6049
Welded in
49537888693_c5c3027d2e_c.jpgIMG_6058
and fitted
49538383346_91757002ac_b.jpgIMG_6061
And done
49538608657_c652397ede_b.jpgthumbnail_image2
49538383591_8b75f9a404_b.jpgthumbnail_image1
First up was changing the rear bumper to a nice Mk2 one..
Then i had to take a look at the brakes, they were pulling to one side and really needed a stomp to get them to work...
Soon found out why! Pad's were welded in place with rust!
49979313411_3834991a01_c.jpgIMG_6359
49979569627_6ed499a2b0_c.jpgIMG_6363
Stripped the brakes off cleaner re-painted and new pads
49978789888_fdf08fc776_c.jpgIMG_6358
Much better
49979569602_be61c6d5af_c.jpgIMG_6403
Then i fabricated a new clutch pot as the old ones look nasty
Old
49978792828_6025902540_b.jpgIMG_6341
New with AN4 Lines
49979316341_b49cab84be_b.jpgIMG_6353
49979572747_4c983fc28a_b.jpgIMG_6354
Next up i wanted to improve the OE airbox as the pipe sizes are tiny and i will eventually be doubling the power
So fabricated this alloy case and s2000 paper filter with ducted inlet from behind the light. This way i get lots of cool fresh air and it allows the engine to breath
49979558552_4c4122a749_b.jpgIMG_6453
Here you can see the large 3" inlet pipe to the sealed airbox, little perspex window is to make sure nothing gets trapped in the box, 4 bolts allow quick removal and changing of the filter. This
all fits in the stock battery tray so no mods to the shell needed.
49979302211_05dbeef821_b.jpgIMG_7195
So with the new airbox in place i now had to find somewhere to fit a battrey. Didn't want it miles away in the boot and no way was i mounting it inside the car. A few years ago a cell went down in
an old car i had and started pumping acid into the cabin of the car... not a great experience...
So here is where the batt was, where the air filter now lives..
49978785568_d63b1e670f_b.jpgIMG_7078
Then i thought, there is some space below the battery tray!
So...
Here is the replacment
49978785628_63c14eb2a4_b.jpgIMG_7073
49979309201_d056407e5b_b.jpgIMG_7072
New mount i made
49979565382_ae2ea32a46_c.jpgIMG_6857
49979565377_aab261e9cc_c.jpgIMG_6859
New location
49979309256_df46421f69_c.jpgIMG_6861
49978785678_e9df5ff9ae_c.jpgIMG_6862
painted and foam to protect the batt
49979565257_250813f85d_c.jpgIMG_7070
49978785648_a7b4a836ae_c.jpgIMG_7071
In place
49978785613_b36f786475_c.jpgIMG_7075
And new leads fitted!
The leads are all stock Jaguar parts for the battery and required no mods, i also get the benifit of a fuse which the Uno never had. The only change was crimping new terminals onto the Uno starter
leads
Looks OE too
49978785608_18555fbe4f_c.jpgIMG_7077
So next up i wanted to make a bonnet lifter rather than using the stay all the time
Simple plate that slides into the reinforced section of bonnet to spread the load
49979467656_b48c911da1_c.jpgIMG_7008
Then a mount bolts onto that
49979467651_af1d924e28_c.jpgIMG_7010
Here you can see the parts
49978943683_3bcfae3706_c.jpgIMG_7003
The long part bolts in the original airbox mount holes so no holes need to be drilled
The ram is from a Mk4 Golf Bonnet
49979467621_56e6489a2b_c.jpgIMG_7012
Another small mod was finishing the rad setup, i had made a temp top hose out of alloy
49978795708_895c93c890_c.jpgIMG_7080
Howver my new AN20 fittings arrived so i welded threaded bungs onto the rad and thermostat and made the new hose
Big!
49979318881_700974e972_c.jpgIMG_6584
49978795698_6af3106a8c_b.jpgIMG_7125
49979575477_80fb72d854_c.jpgIMG_7127
With the theme of AN fittings i also wanted to make a catch can
So made this tank, here is the inside showing the deflection plates and twin filters
49979471016_31493a1c66_k.jpgIMG_6778
Fitting welded to the original breather
49978947083_4850a06c1c_k.jpgIMG_6781
Bolts where to the OE air box went so no holes (theme starting here lol)
You can see the drain at the base
49979470931_b27988a957_k.jpgIMG_7011
Made the lines
49979726637_5bad3d3332_k.jpgIMG_7189
49979726597_584e903a87_k.jpgIMG_7191
49979470841_c8395a1afb_k.jpgIMG_7190
Next on the list is the header tank, hate the big plastic OE one shown here
So been trying to learn some CAD, made these 2 files over a few evenings
49979573862_0348db0427_c.jpgIMG_6570
49979573812_0c16aa8cea_c.jpgIMG_6612
Sent them off to a chap with a 5Axis CNC Machine
And these come back
49978794133_8f59955d01_c.jpgIMG_6822
Fabricated a tank and welded it all up with AN fittings
49979317351_e6d3ee192a_c.jpgIMG_6845
49979573872_497a2ba67a_c.jpgIMG_6846
49979317336_cc239eb0c3_c.jpgIMG_7079
Last item which is still a work in process is the inlet manifold
Currently my car has the stock Mk2/PGT type
Here is an old pic:
So, i wanted the better looking Mk1 Manifold but they have a really old odd fuel injector setup, also no spot for a ICV and just need modernising in gerneral
So a stock old Mk1 Manifold
49978800898_fe2a80e93f_c.jpgIMG_6366
Here you can see the old style angled injector mounts
49979323726_d6aba0aaa5_b.jpgIMG_6367
First job was to smooth them out and remove the old mounts
49978800723_94e6650c88_b.jpgIMG_6406
Both sides done
49978800883_7c5b9d4aeb_b.jpgIMG_6407
Next i tackled the throttle itself. It has no location for a Punto GT TPS and with my future power goals i decided to go for a 57mm (i think) Coupe 20V Turbo throttle body
So, cut off the original
Here you can see the coupe size vs stock!
49979323701_e1caf33984_c.jpgIMG_6409
49979323696_ccb917357e_c.jpgIMG_6466
Needs a bit more taking off the stock manifold
49979580567_315079f8ba_c.jpgIMG_6467
Machined some more out
49979580557_fbe584d440_c.jpgIMG_6469
49978800823_38180f1bd0_c.jpgIMG_6471
Then welded the new coupe TB flange and also new injector bungs for modern style injectors
49978800808_6327b6ac51_c.jpgIMG_7103
49979580422_898154e2a0_b.jpgIMG_7113
Started mocking up the rail also, needed some more work to get it bang level but needed to get the holes in place first
49978800798_2f71356a21_c.jpgIMG_7128
Next up was the throttle cable, needed a new mount for it and i also wanted to suppot the inlet manifold like stock
Made this mount
49979580497_b28e6617d4_c.jpgIMG_7187
Goes here
49979580482_c33b3cec9e_c.jpgIMG_7192
and has a step for supporting the manifold
49979323621_465c008c1c_c.jpgIMG_7193
Test fit
49979580402_f47a1ba6e4_b.jpgIMG_7179
Quite a bit still to do on the manifold but nearly there... The reason the TPS is facing up is due to the ICV height. Normally the ICV would be straight up but there is no space under the bonnet
hence the TB rotation.
Right next up was adding the PGT Heatshield to the Mk1 manifold
50416151132_2c07fff225_k.jpgIMG_7209
50415987726_2f834c28a8_k.jpgIMG_7210
50415987631_be3edb3545_k.jpgIMG_7213
That should help
50415297663_b870c3f878_k.jpgIMG_7214
Next drilled and tapped the servo fititng to take an AN fitting
50416150912_d48a1143c4_k.jpgIMG_7243
50416150832_ab58a9c66d_k.jpgIMG_7244
And test fitted the fuel rail mounts i had designed, these pick up on the original inlet manifold
50415987441_f0b989cf4f_k.jpgIMG_7352
50415297273_78a9a91ddb_k.jpgIMG_7398
Also designed a new rocker cover
50415987166_0002c092c7_k.jpgIMG_7399
All that was left was to paint everything up and refit!
50416148557_59ce711a1c_k.jpgIMG_7460
50415297218_3ef4450ad4_k.jpgIMG_7464
50415987111_dd0f49ce38_k.jpgIMG_7465
50415987041_7f706e7a06_k.jpgIMG_7466
50415297118_160ec247c3_k.jpgIMG_7467
50416149532_a5bcb2b50d_k.jpg652486C4-C40C-4300-8FEC-9021A35FD379
50416150252_bd686fde52_k.jpgIMG_7470
50415986901_d88e74777b_k.jpgIMG_7471
All was going well!
Then...
50416392206_b67f45cbe4_k.jpgIMG_7580
50416150132_1d6812b6d7_k.jpgIMG_7591
Seems when the previous owner changed the headgasket the front row of bolts were either left loose or backed off! The bolts were spinning when i removed them!
New Payne Gasket and Bolts
50416149737_e2b8f1285d_k.jpgIMG_7660
Also took the checked the cam while it was all apart, and it seems one of the lobes were worn
50415986706_b38aaf99e7_k.jpgIMG_7633
So i purchased a new Kent Fast Road Cam!
50416578297_d847bcf1a6_c.jpg117715408_1184049468637512_2615549677328085204_n
50416413651_68592e4500_c.jpg117644035_618733512107272_4780055688313382112_n
Clearances
50415722903_06089276fb_c.jpg117818616_343312560169637_4734051037393991324_n
Meausring old shims
50416149997_509a9b8d54_k.jpgIMG_7654
Working out shim sizes
50415722918_6f23500a69_b.jpg117843743_349823576419308_4090216532369945941_n
New cam in and covered in assembly lube
50415722893_21efdcdbcd_h.jpg117744902_921643884998886_8818175929095699843_n
Engine was really clean!
50416149897_be6e97aa00_k.jpgIMG_7659
All back togther
Back to daily duties!
50416149652_e7968d1959_k.jpgIMG_7692
50415986361_cba6d8af65_k.jpgIMG_7691
hi, i know kind of an old thread, but i have a few questions.... What size are hoses you used for oil/fuel lines?
