Technical TwinAir Gearbox - rebuild or replace ?
glaurenson
Northumberland
Hi All,
Been diagnosed with a stiff gear selector shaft on my TwinAir gearbox.
(It's hard to get into gear at times)
Any recommendations for a gearbox repair/rebuild or source a recon box to put in ?
Wiltshire area, or national delivery to my local garage...
Model
Ypsilon Twinair
2012
Mileage
60000
Hi All,
Out of interest..
5 speed or 6?
There Is a common issue on the 4x4 panda with a component that becomes partially seized
@Herts Hillhopper has posted with this
Out of interest..
5 speed or 6?
Standard 5 speed.
Garage diagnosed it and quoted up to £600 to fix it.. depending what it needed !
Plus the removal refitting/removal costs.. approx £1200 total. Plus a clutch I expect to be sensible.
Standard 5 speed.
Are you having an issue where the lever itself is hard to move, and not 'springing back' to the central position? If so, that is something on the outside of the gearbox (at least, it is on the diesel version and I'd expect it to the same on the TwinAir) and can be fixed by removing nothing more than the battery and cleaning and lubricating an external linkage. Ill add a link to a 'how to' about this in a mo...
Edit: see here... https://www.fiatforum.com/guides/cure-for-a-stiff-gearlever-multijet-4x4.841/
Are you having an issue where the lever itself is hard to move, and not 'springing back' to the central position? If so, that is something on the outside of teh gearbox (at least, it is on the diesel version and I'd expect it to the same on th TwinAir) and can be fixed by removing nothing more than the battery and cleaning and lubricating an external linkage. Ill add a link to a 'how to' about this in a mo...
The garage said they had lubricated all the points they had access to. It will be useful though to double check... thanks .
I'm working away at the moment, so don't have direct access to the car.
Standard 5 speed.
May be cheaper to fit a guaranteed box,
also you might have a DMF..?
I'm not familiar with the TwinAir, but I have a Bravo2 and if the gear selection became stiff,
I'd first disconnect the gear cables that connect the gear lever to the gearbox to try to
determine if the problem was in the gearlever, the cables or internally in the gearbox.
I don't know what type of gear selection mechanism is used on your car so I'm just
suggesting this as a possible diagnostic step before removing the gearbox.
Do you have Cruise Control..?
That may limit G. Box replacement options..
Which end of Wilts are you?
@portland_bill may know of a place still in business
I've not had to use any gearbox specialists since moving to this area, so sadly, no knowledge of any specialists.
As said above, some more diagnosis is needed, to determine if it is cables, lever assembly, selectors on top of gearbox, or internal. Often, if cable adjustment is out, selecting gears will be difficult as the cables are trying to place the selector offset from its desired position.
If it does need gearbox work, there is a specialist in Oldham, started specialising in Puntos, expanded to Panda and others. Might be worth talking to them. https://www.thepuntoshop.co.uk/contact.html
If the clutch is not releasing completely, drag in the gearbox will make selection difficult.
If your garage cannot give a definitive report, with explanation of what they've checked and eliminated, perhaps need a different garage first.
Yes.. first disconnect the cables and then try using the gearstick. If the lever/cables move freely (as they should) then you eliminated those as the cause.
The next thing to try is moving the selectors on top of the gearbox by hand, replicating what the cables do. While you're here, grease everything to buggery. The cables are plastic coated and nylon inside so shouldn't need lube.. but any pivots or levers are metal, so oil them up.
If the gearbox doesn't change gear by direct manual action with the engine not running, then it's gearbox time.. If it only doesn't change gear when the engine is running, then that's more likely a clutch/flywheel issue, rather than the gearbox.
If the gearbox used to moan or whine while you were driving along, or jumped out of gear, or made graunching noises (not including reverse, which does it's own thing) then that would also point to gearbox.
Ralf S.
Thanks.. the thrust bearing is also now making a little noise, so it's new clutch time anyway.
Cheapest local quote so for is around £800-£900 .. if the flywheel needs changing too. (Which it probably will).
I've driven it fine, so maybe it's just the wife's driving too ! 🙄😁😁
I can get a full LUK clutch set including flywheel for £318 so needs about 5 hours of labour on top.
Update. Had the clutch replaced, along with DMF and Slave cylinder. Came to around £900 in total though ☹️
Drives so much better now but clutch is still a bit stiff compared to my zafira 😁
Just an update...had a new clutch kit fitted, along with DMF and Slave cylinder. Around £900 total.
Car drives fine now.
Had a few other little niggly bits done too - mot advisories.
