Technical Twinair engine for 4x4 panda
Juan500
Hi please help is it possible to transplant a twinair engine to replace current engine as I cannot source any 188A engines in South Africa many used 2 cylinder turbos at excellent prices
Engine comes with ECU and when I research it’s basicaly a FIRE engine.
Can it be done, probably
How much will it cost, a lot
Can you just swap the engine and ECU, no
A few of the problems you will encounter
Dual mass flywheel
Different clutch
Different gearbox
The engine and ECU are self contained, You will need the wiring harness
You will now need to patch the new wiring harness to the body computer. Not easy, finding someone willing to touch it in the UK would be zero
Then there's all the small bits pulleys, intercooler, exhaust and so on
