to stop it kinking.
fair enough but its overdone. the tube is like half the original diameter
to stop it kinking.
nah its not kinked.
when it comes to fitting to my car ill tidy it all up. can you use them silicon pipes like the boost pipes for the radiator?
yeah you can use silicon pipes for water as well![]()
jeeez, i think you should take that rad off, kick it around some more then stick it back on....looks a right mess
sorry Craig, its just dawned on me that its YOUR car in that picFor some reason i thought you were using someone elses car for reference! Dopey me.
so with regards to that zip tied pipe, how is it not squashing the insides in? have you chopped it off to see what the pipe will do?
thought i would have the car running today! not quite tho. got it wired up (got it wired as simple as possible with only the needed sensors connected)
The car fires but wont run. I will need to get the timing light out tomorrow. Im running the same wheel settings i am on the N/A and would of expected that to get it going hummm
