to fly or not to fly
If someone tells you the most exciting figure is the loop, do not believe him/her. It is the hammerhead.
:nono: no. hammerhead/stall turn although as you rightly said is better than a loop a flick is better;)
in a loop the G force holds you in a seat, that's why it's boring. a stall turn you go up and then hang loose in your seatbelt which is pretty scary the first time you do it and then the plane falls back down and turns itself in doing so.
a flick is quick, and fun. especially if the plane you're in isn't supposed to be doing flicks :p :D
This should see off your Fokker Triplane, just like it accounted for Von Richthofen.
